Front end alignment
MeeferMadness
MeeferMadness is offline
PostPosted: Thu Sep 20, 2018 12:39 pm    Post subject: Front end alignment Reply with quote
Took my 59 Euro in for an alignment last week. The tech said the camber on the drivers front was out. Just took it apart and re-measured the offset and shims. Measured 6.5mm which is about right. The spindles are from a 60 bug and have the 2mm retainers/seals on them so the shims should total 8 top and bottom. Should there be O rings as well? Anyway everything checks out good so not sure what the issue is. I made sure the link pins were tight before taking it to the shop. Any ideas?
Thanks
Bruce
