Which bell housings for a start-up stand?
rastomas
rastomas is offline
PostPosted: Tue Sep 25, 2018 5:20 pm    Post subject: Re: Which bell housings for a start-up stand? Reply with quote
Thanks!
"It's not 'You are what you eat', it's 'You are what you don't SHIT". Wavy Gravy.
'74 Westy
Wildthings
Wildthings is offline
PostPosted: Tue Sep 25, 2018 3:24 pm    Post subject: Re: Which bell housings for a start-up stand? Reply with quote
SGKent wrote:
Mike - what about the starter mesh? Will an 091 starter mesh with the smaller flywheels?
As far as I know all the ring gears are the same size.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Sep 25, 2018 3:08 pm    Post subject: Re: Which bell housings for a start-up stand? Reply with quote
George Carlin:
Skills@EuroCarsPlus:
Wildthings
PostPosted: Tue Sep 25, 2018 2:20 pm    Post subject: Re: Which bell housings for a start-up stand? Reply with quote
The 091 bellhousing will accept any Bay flywheel and clutch, while the earlier bellhousings will not accept the 228mm clutch without clearancing.
babysnakes
babysnakes is offline
PostPosted: Tue Sep 25, 2018 1:46 pm    Post subject: Re: Which bell housings for a start-up stand? Reply with quote
Most any. I have a 1600 T-1 bolted to a '72 T-2 (for a T-4 engine) trans. Since you will not be using the input shaft you should have no worries.
rastomas
rastomas is offline
PostPosted: Tue Sep 25, 2018 1:21 pm    Post subject: Which bell housings for a start-up stand? Reply with quote
For a 74 type 4, which year bell housings will fit the correct starter?
'74 Westy
