o-town Samba Member
Posted: Sat Nov 24, 2018 7:15 pm Post subject: Re: Spare wheel carrier drawings |
I adapted a spare tire carrier from a gmc SUV. Mounted it through the outside side panel of the d pillar. As the exterior metal on the vanagon body panels is not that thick, I added decent sized steel reinforcement panels from inside the d pillar and it is all held together with bolts.
I was prepared to do further welded in reinforcements but they weren’t necessary
So propose you consider adapting something from a local market SUV. Eg Nissan Pathfinder/ terrano
Otherwise I have seen some use the body seam vertically beside the back hatch as a base attachment point, wrapping out onto the rear of the d pillar beside the hatch to attach swing arm points for a spare tire rack |
peterT3syncro Samba Member
Joined: September 27, 2016 Posts: 76 Location: australia
Posted: Sat Nov 24, 2018 4:58 pm Post subject: Re: Spare wheel carrier drawings |
| rmcd wrote: |
Hey Peter
I had a rust bucket van that I cut up for spare body parts to fix rusted out parts of my van. I was careful to save the rear d-pillar corner so I could use it to mock up the reinforcement pieces.
Maybe you could find a donor van in your hood? |
Thanks mate
A good idea
Looking
Peter _________________ Peter
Type 3 Syncro Kombi, EJ22 Subaru |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1350 Location: PNW - its a dry rain.
Posted: Tue Nov 20, 2018 8:24 pm Post subject: Re: Spare wheel carrier drawings |
Hey Peter
Maybe you could find a donor van in your hood? _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Tue Nov 20, 2018 4:00 am Post subject: Spare wheel carrier drawings |
Hi there
I'm wondering if anyone has created a detail drawing for a spare wheel carrier, with regards to the piece of steel located against the rear hatch in which the device hinges from? And the piece inside the duct which this piece bolts to.?
Living here in Australia no one makes anything like this here and freight from US is rather costly. Many $$$$$ !
thanks
