FreeBug Samba Member
Joined: March 12, 2012 Posts: 4277 Location: deepest, darkest Switzerland
Posted: Sun Jan 27, 2019 11:43 pm Post subject: Re: Stock Crank Pulley Difference? |
I stubled on it by accident...and discovered no one i spoke to knew this, even my parts supplier. I wonder how many used 1300 pulleys they sold ended up mounted on 1600s...and how much does it rezlly affect temps?
But seeing as how VW rationalised production for max savings, if the y hadn't needed to design a new pulley, they wouldn't have. |
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 857 Location: clearwater,florida
Posted: Sun Jan 27, 2019 2:21 pm Post subject: Re: Stock Crank Pulley Difference? |
So I have just run into this, and have not sorted it out yet. I have the larger 7inch stock pulley on the bottom, and the Alternator has a normal looking Generator pulley on it. Both OE German. My Alternator Belt is too short to fit. I have the longer of the two belts with the 11mm wide section. I do have a smaller 6 3/4 OEM bottom pulley, am I supposed to have that small pulley when using an Alternator? I honestly have never used anything but a Generator ever, so this one has me baffled a little also. As for the 1300 smaller pulley, that I did not know either. _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
Posted: Sun Jan 27, 2019 12:09 pm Post subject: Re: Stock Crank Pulley Difference? |
| 1300 pulley is slightly smaller in diameter than the 1600's. |
Fifty-Eight Rag Samba Member
Joined: September 07, 2011 Posts: 936 Location: St. Louis, MO
