Posted: Sat Apr 13, 2019 1:29 pm Post subject: Re: Rekeying a lock - help needed |
You can only use the wafers that you can make work, if you can make 5 out of 8 wafers work then you can just do that.
WD40 does a good enough job of cleaning. As for relubricating the lock that would depends somewhat on where you live. Maybe check with your local locksmiths and see what they like. |
spacebiscuit Samba Member
Posted: Fri Apr 12, 2019 1:44 pm Post subject: Rekeying a lock - help needed |
Looking for some help and advice re-keying my tailgate lock. I have removed the lock and the barell and the wafers. With no wafers my keys slips in all the way. What am I trying to achieve? Do I fit the wafers one at a time using trial and error until I can insert the keys without any wafers protruding? I have 8 wafers in total, does a VW lock of this age always use 8 wafers?
Also to what extent should I clean the barell and the wafers, there is alot of gunk and crap that has fallen out, but should I soak the barell? I am guessing a certain amount of grease is required for good operation? _________________ 1972 Type 2 1600cc
1990 MKII Golf 1.6 CL |
