What to set timing to??
JohnB53
JohnB53 is offline
PostPosted: Sat Jun 01, 2019 12:09 pm    Post subject: Re: What to set timing to?? Reply with quote
THANK YOU
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Jun 01, 2019 11:58 am    Post subject: Re: What to set timing to?? Reply with quote
JohnB53 wrote:
Sorry this is what is on the dissy
JUV-4
0-231-137-009
113-905-205-K
Timing Set At:: 7.5deg BTDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
JohnB53
JohnB53 is offline
PostPosted: Sat Jun 01, 2019 11:04 am    Post subject: Re: What to set timing to?? Reply with quote
JUV-4
0-231-137-009
113-905-205-K
ekacpuc
ekacpuc is offline
PostPosted: Sat Jun 01, 2019 11:03 am    Post subject: Re: What to set timing to?? Reply with quote
Glenn wrote:
please post the actual model number of the "dissy".
Post the numbers on the side. Incase you didn’t know where to look to figure out the model.
Mr. 010
Glenn is offline
PostPosted: Sat Jun 01, 2019 10:45 am    Post subject: Re: What to set timing to?? Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
JohnB53
JohnB53 is offline
PostPosted: Sat Jun 01, 2019 10:21 am    Post subject: What to set timing to?? Reply with quote
Hi All This winter I rebuilt a VW motor for my home made trike. It was based on a 1500 single port motor I was given. I ended up with a 1641 single port with stock dissy 5-67 bug, stock 30 Pict-2 carb, stock vw cam from Appletree parts. I have an alt so I needed the carb spacer for clearance. I am wondering what should I time this bad boy at? 7.5 BTDC or 0 TDC also with these distribs do you unhook the vacuum line while timing . I hope these questions are not too dumb as I am new to this vw way of life. Thanks John
