Do You Wax ??
Page: 1, 2, 3  Next
Do You Wax the Vanagon ??
Yes
59%
 59%  [ 25 ]
No
40%
 40%  [ 17 ]
Total Votes : 42
SCM
SCM is offline
PostPosted: Tue Jun 11, 2019 3:13 pm    Post subject: Re: Do You Wax ?? Reply with quote
I wax mine once a year but it's bitter-sweet.
Mine has a zillion tiny scratches in the paint that seem to hold dirt very well. Even after a thorough wash with the "foaming brush", once the van dries it looks like I never washed it all. Unfortunately, the only way to make it look clean IS to wax it after washing. I suppose this is also grinding even more little scratches into the paint but, oh well.
I once tried using a buffing compound with an orbital buffer to smooth out the paint but it didn't seem to do much.
My wife and are in agreement that we bought it to use so the rough finish makes those desert pinstripes less painful.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
TequilaSunSet
TequilaSunSet is offline
PostPosted: Tue Jun 11, 2019 2:30 pm    Post subject: Re: Do You Wax ?? Reply with quote
I haven't washed mine in years, undergoing natural patina Laughing Laughing
Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me
E1
E1 is offline
PostPosted: Tue Jun 11, 2019 1:52 pm    Post subject: Re: Do You Wax ?? Reply with quote
Only if the cracks are wax-sealed but even then, doubtful.
1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
— Colin Chapman
llilibel03
llilibel03 is offline
PostPosted: Tue Jun 11, 2019 12:53 pm    Post subject: Re: Do You Wax ?? Reply with quote
Does putting wax frequently on the seams delay rust?
87 syncro tintop
90 gl tin top
85 westy 2.0 tiico automatic (present)
Tbob
Tbob is offline
PostPosted: Mon Jun 10, 2019 8:48 pm    Post subject: Re: Do You Wax ?? Reply with quote
I own several vehicles, nothing newer than a 2002. I wax them all by hand, and on the Volkswagens, I use a product that use to be called J wax Kit, by Johnson wax. I have been using it since the 1970's. I like the way the paint responds to it, it really seems to help my 45 year old paint shine. It doesn't seem to be the longest lasting( it seems to look good for about 6-8 weeks) but it is easy to put on and easy to take off. Johnsons sold the company several years back, and it is now known as Formula 1 wax. I have tried all kinds of brands of waxes over the years, and I keep coming back to this brand.
1969 Deluxe, owned since 1973
1973 Westfalia, owned since 1983
1980 Westfalia, watercooled conversion
1985 Westfalia, stock!
1986 Westfakia, Audi I-4 conversion
A couple of trucks and a couple of Jeeps
Merian
Merian is offline
PostPosted: Mon Jun 10, 2019 7:29 pm    Post subject: Re: Do You Wax ?? Reply with quote
Cons. Reports found that paste waxes lasted longer than liquids (but of course are a bit more laborious to apply - I use a random orbit sander with a wax pad on it)
I am trying to use up all the extra Meguiars Gold Class I have. Their NXT was a lot better...
Meguiars tells me that Ultimate is their best for paint protection; does not leave any residual product on plastics or rubber
Meguiars Hybrid Ceramic Wax - better water repellant; last same as Ult. Fast Finish; different apps. procedures for the two (I tried this on the Vanagon - just squirt it on and hose off with 120 psi garden hose & nozzle & I really seemed to make it easier to get mud off).
Tested by Cons. Reports 2011, updated 2016:
Nu Finish NFP-80 car wax (soft paste can) - rated 71 (best); xlnt. Durability; only got a Good for Gloss
Meguiars Gold Class Liquid - rated 68; Fair Durability (but rated much better than Gold Class paste wax)
Meguiars NXT - rated 69; Fair Durability (but was best liquid); Very Good for Gloss
most products had a significant loss of protection within about 5 weeks
some years ago I tried a spendy & fancy wax vs. Meguiars - it was no better
I agree with a post above that surface prep. is critical - cleaner/polish/clay bar (if needed). Even an ugly dark brown color (name withheld) looks really nice when it's all shiny.
coqcitywesty
coqcitywesty is offline
PostPosted: Mon Jun 10, 2019 4:11 pm    Post subject: Re: Do You Wax ?? Reply with quote
For single stage paint, I use Meguiars Gold Class and for clear coat finishes, I use Meguiars Ultimate Wax. Ultimate is really easy to apply and remove and lasts a long time. My single stage car is under a wrap and stored dry and never sees inclement weather, so while the Gold Class also works/lasts exceptionally well on it, under 'normal' use, results may vary. While quality waxes and polishes (Meguiars, Mothers, Chemical Guys etc) may cost more up front, the ease of use (less time to apply), coupled with the better results and performance more than makes up for the initial investment, IMHO.
1991 Westfalia EJ251, 1972 Volvo 1800 ES
llilibel03
PostPosted: Mon Jun 10, 2019 3:46 pm    Post subject: Re: Do You Wax ?? Reply with quote
Ahwahnee wrote:
I do not wax the engine...
...but I do enjoy it being clean.
How do you keep it so clean????
87 syncro tintop
90 gl tin top
E1
E1 is offline
PostPosted: Mon Jun 10, 2019 9:54 am    Post subject: Re: Do You Wax ?? Reply with quote
Yep. Any paint I can see and reach gets minted. Behind the glovebox, deep into the flow-through vents, etc. Engine bay, someday...
Not to be "anal" as much as we have a mailbox on the roof. Wink
Once inside panels are mint, they stay that way for years and don't need much if any upkeep. The van was filthy when buying it and am within hours of finishing a solid week of visual and mechanical upkeep.
Best thing I've ever found for the cabinets is Protect All Fiberglass Oxidation Remover, originally bought to bring the roof finish back. Works great on the roof, too.
Per the front of the license plate holder, not yet -- gotta remove the oily foam first. Might today. Wink
— Colin Chapman
Abscate Premium Member
Abscate is offline
PostPosted: Mon Jun 10, 2019 9:18 am    Post subject: Re: Do You Wax ?? Reply with quote
Much more important.
Do you remove the rear license plate to wax underneath (or for the pedandicks, in front of it?)
E1
E1 is offline
PostPosted: Mon Jun 10, 2019 9:03 am    Post subject: Re: Do You Wax ?? Reply with quote
Historically, Yes on Meguiar's. I hear them compared to Mother's all the time but see no comparative value beyond the "M."
(though Mother's mag wheel polish is great, if finished off with a baking soda or even corn starch wipe to remove the slime).
I may try Meguiar's paste, I think they make that still but never see it. Very pleased with Nu-Finish liquid wax but always open to finding something better.
Best product I ever used for that last glaze on fresh paint in my custom painter days was Liquid Ebony. Magic.
— Colin Chapman
coqcitywesty
PostPosted: Mon Jun 10, 2019 8:55 am    Post subject: Re: Do You Wax ?? Reply with quote
E1 wrote:
Is it wrong to admit my doors jambs are mint? Laughing
No, wear it as a badge of honor as I do. I wash, wax and even clay bar all four of the vehicles I maintain on a regular basis as I am anal and love the end results. I do not see it as work, rather as somewhat therapeutic. One could likely eat off my door jambs, provided that they cleaned and waxed them afterwards. While my 91 will require a repaint at some point as there is some crappy PO clearcoat issues that cannot be readily corrected, it continues to get a lot of love when parked for its overall cleanliness. BTW - as noted above the new wax products ( I use primarily Meguiars) are far less onerous to apply and remove, which certainly makes the task that much enjoyable.
jlrftype7
jlrftype7 is offline
PostPosted: Mon Jun 10, 2019 6:34 am    Post subject: Re: Do You Wax ?? Reply with quote
shagginwagon83 wrote:
jlrftype7 wrote:
Mine does too, is your 83 1/2 different?
Yeah I think I have bracket on backwards.
Old photo.
Easy to fix though... Cool
‘84 Tin Top - Hilga....Auto
74 Thing
74 Thing is offline
PostPosted: Mon Jun 10, 2019 6:28 am    Post subject: Re: Do You Wax ?? Reply with quote
Wash, decontaminate (clay and iron removal), polish, and protect should be normal care to any vehicle.
I don't usually use wax now since carnuba usually deteriorates very quickly and you can get better protection out of sealants or coatings. Check out autogeek.net
tencentlife
tencentlife is offline
PostPosted: Mon Jun 10, 2019 5:38 am    Post subject: Re: Do You Wax ?? Reply with quote
I would have to wash it first.
Experience is death to doctrine.
Alaskaberrys Premium Member
Alaskaberrys is offline
PostPosted: Sun Jun 09, 2019 11:02 pm    Post subject: Re: Do You Wax ?? Reply with quote
Only can claim to wax if turning the wand at the do it yourself car wash to “wax” counts (and actually does anything). This is after a trip and just before wrapping her up in the cover for a month or three. I figure it may help to keep from chafing. Otherwise, paint is so tired we’ve never really been motivated to do so...
vegpedlr
vegpedlr is offline
PostPosted: Sun Jun 09, 2019 9:50 pm    Post subject: Re: Do You Wax ?? Reply with quote
I’m going to.
The previous owner waxed it before I first saw it and it made the ratty appearance a bit. Then the deluge hit it with weeks of rain. I figure some wax might help preserve what’s left of the paint and bondo. Plus, it’ll get better mileage and go faster too.
1985 Tintop 4 sp GW 2.3 “Connie”
2006 Mk V GTI 2.0 FSI “Penelope”
andrewvwco
andrewvwco is offline
PostPosted: Sun Jun 09, 2019 8:52 pm    Post subject: Re: Do You Wax ?? Reply with quote
llilibel03 wrote:
andrewvwco wrote:
I waited a year before I waxed mine. Got tons of black, road git, and bugs form the van mostly under the Bra shinned like new after and I could tell she was happy.
Not OG paint but helped very much.
Related question- I too have painted the lower panels black, in my case I used Rustoleum truck bed liner. When I have waxed my van any wax on the texture stays there. Looks bad. Same with other rubber or black plastic bits.
Anyone have tricks for this task/problem?
Yea man I just take some more rustoleum and put it over it. It does turn very white form the wax. I do them both 1 time a year on a nice day. On the bumpers I use back to black 2-3 times I try to wax slow but always get some on the black areas too.
You could try to use painters tape to block it from happening as well.
Be here now, not in the past and not in the future, but be here now.
shagginwagon83 Premium Member
shagginwagon83 is online now
PostPosted: Sun Jun 09, 2019 8:22 pm    Post subject: Re: Do You Wax ?? Reply with quote
Old photo.
Instagram: @joannthevan
E1
E1 is offline
PostPosted: Sun Jun 09, 2019 8:09 pm    Post subject: Re: Do You Wax ?? Reply with quote
Tomorrow I wax for the second time this week, third time since purchase in October, and probably the van's fourth time since the '90s. POs suck. Wink
Just because I can. Nothing beats resurrecting dull paint. Okay, maybe space travel does.
— Colin Chapman
Page: 1, 2, 3  Next
