2.1 WBX to AHU conversion - fuel pump?
leecat
leecat is offline
PostPosted: Mon Jul 15, 2019 8:08 am    Post subject: Re: 2.1 WBX to AHU conversion - fuel pump? Reply with quote
I run the AHU and have never had any need for a lift pump of any kind either, runs like a champ just with the stock injector pump.
joelsolomonson
joelsolomonson is offline
PostPosted: Sun Jul 14, 2019 11:10 pm    Post subject: Re: 2.1 WBX to AHU conversion - fuel pump? Reply with quote
Got it. Thanks for the explanation.
hans j
hans j is offline
PostPosted: Sun Jul 14, 2019 11:04 pm    Post subject: Re: 2.1 WBX to AHU conversion - fuel pump? Reply with quote
Delete it, it runs way too high of pressure for the injection pump.
If you would like a lift pump, you only need a small one with low pressure. You will also have to wire in a relay for it because the stock gas fuel pump is run by the ECM, which all gets removed during the conversion.
1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181
joelsolomonson
PostPosted: Sun Jul 14, 2019 10:04 pm    Post subject: 2.1 WBX to AHU conversion - fuel pump? Reply with quote
For those who have gone from stock gas to diesel, does the gas fuel pump get deleted? Does anybody keep it in place and use it like a lift pump? Is it compatible with diesel? Thanks
