Cylinders stuck in case - any tips?
jeffrey8164
jeffrey8164 is offline
PostPosted: Thu Aug 22, 2019 3:25 pm    Post subject: Re: Cylinders stuck in case - any tips? Reply with quote
I’ve had to break them off before too.
Usually though, those were junk yard or back yard engines that sat in the elements for a few years.
Volkswagen!
(Compression 8.7:1)
cbeck
cbeck is offline
PostPosted: Thu Aug 22, 2019 3:09 pm    Post subject: Re: Cylinders stuck in case - any tips? Reply with quote
When the rubber mallet doesn't work, get a real hammer and get medieval with it.
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
RWK
RWK is offline
PostPosted: Thu Aug 22, 2019 2:34 pm    Post subject: Re: Cylinders stuck in case - any tips? Reply with quote
Heat the case not cylinders, maybe put two studs thru opposite corners of cylinders and long bar between and try to twist to break bond? maybe less chance of breaking fins, check case drain plate, maybe all corroded and case junk, as was the last one I tore apart, busted cylinders and saved crank,rods and flywheel
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Thu Aug 22, 2019 1:12 pm    Post subject: Re: Cylinders stuck in case - any tips? Reply with quote
Ever had to cut them off with a die grinder? I have
FreeBug
FreeBug is offline
PostPosted: Thu Aug 22, 2019 1:02 pm    Post subject: Re: Cylinders stuck in case - any tips? Reply with quote
I'm thinking there's oxidation and electrolysis who ganged up to make your life hell.
Have you tried the ATF /acetone combo? I really can't think of anything special, like VWporscheGT3 said, a rubber mallet and patience, look out not to break fins.
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Thu Aug 22, 2019 8:06 am    Post subject: Re: Cylinders stuck in case - any tips? Reply with quote
rubber dead blow. smack the cylinder all the way around, and then at about a 95 degree angle and they should come out. the piston isn't rusted solid in there right?
pre67vw
pre67vw is offline
PostPosted: Thu Aug 22, 2019 7:58 am    Post subject: Cylinders stuck in case - any tips? Reply with quote
I have a 36hp motor that we're trying to rebuild, but the cylinders are stuck solid in the case. Any tips on how to remove them? They've been soaked with WD40, heat has been used, nothing seems to help. Is there some kind of puller that can be used?
www.pre67vw.com
