Wheel Offset
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Typ3nut
Typ3nut is offline
PostPosted: Tue Jul 14, 2020 4:09 pm    Post subject: Re: Wheel Offset Reply with quote
gt1953 wrote:
I have scene several stock wheels with the offset stamped on it. ET34 ET 41 ET 46.
So what is the offset with the wheel only has a T on it like the photo below.
T stamped VW Wheel
Rome
Rome is offline
PostPosted: Sun Jun 07, 2020 8:35 pm    Post subject: Re: Wheel Offset Reply with quote
'Nut, thank you for posting those really helpful Lemmerz tables. Even though I'm fluent in German and have a good understanding of technical German, I cannot guess what the abbreviations are in column 4- Radausfuehrung- wheel version. The letters are probably an indicator as to the wheel style. Was trying to find a pattern or commonality. For example, a "hubcap" wheel vs an open one of the same width and offset. Or a "Baja Champion" wheel (4.5", ET34) compared to a Sport wheel (the one with the "+" spoke design) on the 1974 Love Bug special edition which was also 4.5" with ET34. "Sp" could either be Sport, or Spezial (special). Porsche 914 had both a hubcap wheel 5.5" with ET40, as well as a Sport steel wheel in the same size and offset. Only one 5.5" is listed. Maybe the other wheel style came from another supplier such as Suedrad or Kronprinz (logo KPZ).
Typ3nut
Typ3nut is offline
PostPosted: Tue May 26, 2020 7:46 pm    Post subject: Re: Wheel Offset Reply with quote
gt1953, Went through some 4 1/2j x 15 wheels today and had one that has the "T" and is stamped ET41.
http://vw.zenseeker.net/Wheels-BoltPattern.htm
Also is listed on the above chart as ET41 so, mystery solved on the 4 1/2".
Fits Super Beetle 71-79 & Porsche 914 70-76
Typ3nut
Typ3nut is offline
PostPosted: Wed May 20, 2020 9:09 am    Post subject: Re: Wheel Offset Reply with quote
Volkswagen Factory Wheel Bolt Pattern Offset/ET, Backspacing
Volkswagen & Porsche Stock Wheel Chart : LEMMERZ
4 & 5 Lug Bolt Patterns, 205, 130, 112, 100
Wheel Sizes, Width & Offset / ET
Identifing LEMMERZ Wheel Stampings:
Wheel ID:
Year Produced:
Wheel Width & Size
Typ3nut
Typ3nut is offline
PostPosted: Mon Oct 07, 2019 5:35 pm    Post subject: Re: Wheel Offset Reply with quote
I know it baffles me too on the offset but these wheels with the "T" work great on my Type 3 cars.
gt1953
gt1953 is offline
PostPosted: Mon Oct 07, 2019 2:03 pm    Post subject: Re: Wheel Offset Reply with quote
Well I have measured the ET 34 and ET 46. The one with the "T" is neither. It is in between them. So hmmm. The mystery goes on.
72 type 1
72 Squareback
Typ3nut
Typ3nut is offline
PostPosted: Sun Oct 06, 2019 4:42 pm    Post subject: Re: Wheel Offset Reply with quote
I'm replying to this post because I also have asked this question before with no reply. So I'm not sure what "T" is but this is what I have surmised ...
15" x 4 1/2J" - 46mm / et, these I have found mostly from Karmann Ghia, Type 4 and Porsche 914
15" x 5 1/2J" - 41mm / et, these are from Porsche 914
The one I have are dated in the early 1970's and marked VW
gt1953
gt1953 is offline
PostPosted: Sun Oct 06, 2019 3:23 pm    Post subject: Wheel Offset Reply with quote
72 type 1
72 Squareback
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
