Suicide piano hinge quarterlights.
Lowdown Dirty Rat
Lowdown Dirty Rat is offline
PostPosted: Mon Oct 14, 2019 11:06 am    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
Style 1 (non-moved pivot).
The hot climate link would make sense. Like they are just pre-safaris.
But all the brochure buses and all the style 2 suicide quarters were on cold climate buses.
1951 Samba 20-017894
1952 Samba 20-028952
djfordmanjack
djfordmanjack is offline
PostPosted: Mon Oct 14, 2019 2:11 am    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
ooooh my eyes hurt....the typical SA import craze. 195k....yeah. Although it presents nicely and sure has suicide vents, but there is so much wrong on this one... can't believe they used later cargo floors...ouch! Mad Crying or Very sad
Concerning the suicide vent discussion, this bus obviously came from hot climate out of South America.
54 Oval project
62 Dickholmer, Seeblau L360
olebarndoor51
olebarndoor51 is offline
PostPosted: Mon Oct 14, 2019 1:59 am    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
Look at this panel, also suicide.....
https://www.willhaben.at/iad/gebrauchtwagen/d/auto/vw-t1-barndoor-338022548/
chthemonkey
chthemonkey is offline
PostPosted: Sat Oct 12, 2019 5:49 am    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
there's a nos quarter with the piano hinge on in the for sale section custom and commercial are selling it Im not sure how to post a like but I typed in the search barndoor light scroll down bit and its there
Lowdown Dirty Rat
PostPosted: Fri Oct 11, 2019 2:10 pm    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
Confused On second thoughts
Well progressive refinements suggest they changed at the same time. 20-041712
But factory photos suggest a slight lag to the mirrors. Possibly using up old stock?
Lowdown Dirty Rat
PostPosted: Fri Oct 11, 2019 1:55 pm    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
The quarterlight changed to the swivel type before the mirror dropped down. Dec 52s have swivel quarters and upward mirrors.
djfordmanjack
PostPosted: Fri Oct 11, 2019 11:55 am    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
another point. Does anyone else think there could be a connection between the early style high mounted outside rearview mirror and the (optional) suicide style quarterlights?
I believe that the later ('53up) lower mirror could have gotten in the way of the suicide vent wings both visible and physical.
54 Oval project
Lowdown Dirty Rat
PostPosted: Thu Oct 10, 2019 9:03 am    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
As far as I’m aware there is only evidence of one original piano-hinge Barndoor with safaris. And that was in the First factory safari fitting guide so was almost certainly the prototype/demonstration vehicle.
When the piano hinge quarter was changed, so was the A-pillar. The old A-pillar was not very conducive with fitting safaris.
The piano hinge quarter pictured with the safaris appears to be a regular non-suicide type.
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Wed Oct 09, 2019 11:01 pm    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
Did these suicide windows exist in the same time frame as Safari windows. Have factory offerings of both been seen on one bus?
https://instagram.com/mr.ogpaint
Patrick Hall
Lowdown Dirty Rat
PostPosted: Wed Oct 09, 2019 2:57 am    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
And of course my bus 😉
Mr. OGPaint
PostPosted: Tue Oct 08, 2019 9:50 pm    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
Thank you for sharing. I was recently sharing that I would really like to make a set of these, at the time I had no idea it had been a factory offering. Then I heard about them in the other thread and have been intrigued since.
Patrick Hall
Lowdown Dirty Rat
PostPosted: Tue Oct 08, 2019 1:54 pm    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
Here’s a bunch more.
Are both styles factory?
Or only the fully edited (2) type?
Are type 1 edits just aftermarket/dealer changes?
Lowdown Dirty Rat
PostPosted: Tue Oct 08, 2019 1:45 pm    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
Notice though that there are two different types.
1. Where just the hinge has been swapped but the catch point Remains in the same location as a non-suicide quarterlight. This results in the window opening much wider then usual.
2. The hinge has been swapped but the catch point is also different. Spaced from the hinge as it is for non-suicide quarterlights ensuring they window only opens to the same degree as a normal one would.
Standard quarter on an early microbus with a fully edited deluxe suicide Quarter pictured below.
Lowdown Dirty Rat
PostPosted: Tue Oct 08, 2019 1:35 pm    Post subject: Re: Suicide piano hinge quarterlights. Reply with quote
But also most probably factory on panel vans too.
And ambulances.
Lowdown Dirty Rat
PostPosted: Tue Oct 08, 2019 1:30 pm    Post subject: Suicide piano hinge quarterlights. Reply with quote
I’m bored, so I thought I’d write this thread on what I know about suicide piano hinge quarters as I was talking about mine at benpon gathering and again it recently came up in the Barndoor vintage photo thread.
They seem to have definitely been a factory option
On microbuses and deluxes at least.
