Stupid Solex Question
Pastelweis
Pastelweis is offline
PostPosted: Fri Nov 22, 2019 11:49 am    Post subject: Re: Stupid Solex Question Reply with quote
xyzzy wrote:
Pastelweis wrote:
Yes, Question is, what is supposed to be there? Rolling Eyes Very Happy
A smaller bolt with a felt washer?
”My clean air tube” Embarassed
Yes, look at the picture I posted, on the left side you can see the correct bolt.
Were you driving when this happened? I find it hard to imagine the bus would run without that bolt and without starting a huge immediate fire. Perhaps the bolt is under the clean air tube?
I wasn’t actually with the bus myself when it was discovered. It was with a body shop. And yes I did find the original bolt below the air hose on the engine tin. Smile
Pastelweis
PostPosted: Fri Nov 22, 2019 11:46 am    Post subject: Re: Stupid Solex Question Reply with quote
Abscate wrote:
Yikes. You dumped about 200 mL of petrol when that happened. Enough to start a nice fire. Check the other one too!
Good advice, other was fine, thank you!
xyzzy
xyzzy is offline
PostPosted: Wed Nov 13, 2019 10:49 am    Post subject: Re: Stupid Solex Question Reply with quote
1973 VW Westfalia 2L hydraulic, dual Solex PDSIT
1987 VW Vanagon Westfalia
Pastelweis
PostPosted: Wed Nov 13, 2019 10:09 am    Post subject: Re: Stupid Solex Question Reply with quote
SamboSamba22
SamboSamba22 is offline
PostPosted: Wed Nov 13, 2019 7:23 am    Post subject: Re: Stupid Solex Question Reply with quote
May I suggest finding a smaller bolt with a felt-like material to button that carb up.
We want miles and smiles in our community, not fires and dires....straits well, a couple tunes is okay with me.
Glad you reached out, and found help from these awesome guys. Good luck,
Sam
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
Abscate
Abscate is offline
PostPosted: Wed Nov 13, 2019 1:44 am    Post subject: Re: Stupid Solex Question Reply with quote
Pastelweis
PostPosted: Wed Nov 13, 2019 1:30 am    Post subject: Re: Stupid Solex Question Reply with quote
Here is a picture of the front facing side. Bus is not automatic ... nothing was removed in order to take the picture. Thank you to everyone taking the time to answer my questions. I’ll try my best to pay it forward.
Smile
busdaddy
busdaddy is offline
PostPosted: Tue Nov 12, 2019 9:03 am    Post subject: Re: Stupid Solex Question Reply with quote
xyzzy wrote:
What is that shiny brass knob to the right of your replacement bolt, rubbing the clean air intake tube?
Thermal accelerator pump valve, usually found on automatic transmission buses.
Слава Україні!
xyzzy
xyzzy is offline
PostPosted: Tue Nov 12, 2019 8:24 am    Post subject: Re: Stupid Solex Question Reply with quote
Wow -- the bus was running prior to noticing this? If that bolt is out, all of the fuel would be streaming out of the carb.... Maybe the bolt is hiding under your clean air tube.
Here's a shot of a right Solex PDSIT carb that shows the bold (on the left of the bowl):
It also looks like maybe your air horn isnt' sealed on top of the carb, unless maybe it was disconnected to get your pic.
Pastelweis
PostPosted: Mon Nov 11, 2019 11:18 am    Post subject: Re: Stupid Solex Question Reply with quote
Hi! Yes, not the best angle I agree. I will take another picture when I am with the bus. Thank you!
/Johan
SamboSamba22
PostPosted: Mon Nov 11, 2019 9:34 am    Post subject: Re: Stupid Solex Question Reply with quote
Is it the brass closing/sealing bolt that goes to the bowl of the carb? The one you remove to gain access to the main jet? Usually accompanied by a red soft material washer?
Could you get an image of the other side of the carb, that way we are looking at the side of it where the bolt is inserted?
Pastelweis
PostPosted: Mon Nov 11, 2019 9:31 am    Post subject: Stupid Solex Question Reply with quote
Hi!
I had a look at the Solex exploded view but couldn’t really makes sense of it so asking here. “Something” went missing from the right Carb on my 76 dual Solex bay. It was leaking gas so we had to put a bolt in temporarily just to drive it back home. What is the missing piece? Is it a brass needle vavle or what?
Please see pic where bolt is inserted ...
Any helpful answer from this awesome community greatly appreciated!
