Heater hose rubbers?
busdaddy
busdaddy is offline
PostPosted: Sat Jan 04, 2020 5:24 pm    Post subject: Re: Heater hose rubbers? Reply with quote
SGKent wrote:
asiab3 wrote:
SGKent wrote:
To this day I still don't know why one of the bellows is supposed to be short and the other long.
That's a Type 4 bus only thing… OP has a Type 1, which uses the same length on both sides. (211 255 387) As for why VW changed it? I have no idea. Similar lengths fit just fine, but a right (388) usually won't stretch to fit on a late bay left side.
Robbie
still don't get why one needs to be 2" shorter. The distance is about the same with a tape measure. I'll have to check it out again when I put the engine back in.
It matters on a type 1, the offset of the cylinder banks (crank journals) makes the trip to the body longer on one side, most type 4 systems make up the difference with longer metal tubes on one side.
Слава Україні!
kreemoweet
kreemoweet is offline
PostPosted: Sat Jan 04, 2020 4:32 pm    Post subject: Re: Heater hose rubbers? Reply with quote
madscientist wrote:
I know I need a set of rubber seals between the accordion hose and body like these ...
Those short seals that CIP1 (and others) sell will not protect your accordian tubes from melting by themselves. They are just too short. You
can see that the outer black plastic is exposed to the hot air if that's all you use. If the engine gets really hot, you
could end up like the guy in this thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8023303
'67 bug: seized by the authorities
my59
my59 is offline
PostPosted: Sat Jan 04, 2020 3:09 pm    Post subject: Re: Heater hose rubbers? Reply with quote
Without the insulation ends, the plastic pipe ends will melt. I swapped out the asbestos cuffs for vanagon silicone ones and made replacement liners.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
SGKent Premium Member
SGKent is offline
PostPosted: Sat Jan 04, 2020 2:26 pm    Post subject: Re: Heater hose rubbers? Reply with quote
Robbie
madscientist
madscientist is offline
PostPosted: Sat Jan 04, 2020 1:36 pm    Post subject: Re: Heater hose rubbers? Reply with quote
sebgi1 wrote:
I use silicone hose reducer 51 to 60mm it will fit just fine. wall thickness is about 5mm
60mm hose cut to lenght will fit just fine too.
edit: this is for a 73 maybe the inner diameter will be different
I never thought of those..
I already put a set on my intakes since the s*&tty ethanol gas eats a pair about every 2 years.
I feel bad because when I see you are Quebec all I can think of LetteryKenny and all that “good fishing in Kyu bec....”
Thanks for the tip on the silicone boots.
sebgi1
sebgi1 is offline
PostPosted: Sat Jan 04, 2020 7:14 am    Post subject: Re: Heater hose rubbers? Reply with quote
SEB
Dogs are the most precious and valuable possession of mankind. VWs are second!
'73 Neptune blue safare camper
'71 Neptune blue tintop
Boesen
Boesen is offline
PostPosted: Sat Jan 04, 2020 5:36 am    Post subject: Re: Heater hose rubbers? Reply with quote
https://www.thesamba.com/vw/classifieds/detail.php?id=2276908
I use these in place of the old asbestos. Both my 79 with a Type 4 engine and my 68 with a type1 engine. Couple different people sell them in the classifieds.
1979 Westfalia Deluxe http://www.thesamba.com/vw/forum/viewtopic.php?t=474334&highlight=iowa
airschooled
Air-Schooled
airschooled is offline
PostPosted: Fri Jan 03, 2020 11:34 pm    Post subject: Re: Heater hose rubbers? Reply with quote
Robbie
www.airschooled.com
SGKent is offline
PostPosted: Fri Jan 03, 2020 9:56 pm    Post subject: Re: Heater hose rubbers? Reply with quote
To this day I still don't know why one of the bellows is supposed to be short and the other long. I'm using two the same length and they work fine. That said, those fellers get up to about 300F as I recall. Make sure nothing in them will melt at that temp. This is all that was left of an aftermarket part that was supposed to be a replacement.
Also the white stuff on the original metal inserts is asbestos. The vanagon cuffs are silicone. Some are grey and some orange. 251-255-393 d
Wildthings
Wildthings is offline
PostPosted: Fri Jan 03, 2020 2:14 pm    Post subject: Re: Heater hose rubbers? Reply with quote
There is a set on each end of the tubes, you need four bushings total.
ivwshane
ivwshane is offline
PostPosted: Fri Jan 03, 2020 2:05 pm    Post subject: Re: Heater hose rubbers? Reply with quote
I’m guessing VW had the cuff there for a reason and it’s either to help seal the connection or to keep from melting the plastic or both. I made my own cuffs using high temp silicon mat I bought off of eBay.
https://www.ebay.com/itm/High-Temp-12-x-12-Black-S...1856876732
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
madscientist
PostPosted: Fri Jan 03, 2020 1:04 pm    Post subject: Heater hose rubbers? Reply with quote
I know I need a set of rubber seals between the accordion hose and body like these.
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-111-819-945-PR
But do I need another set to keep the tubes from melting when I connect them straight to the heater box?
I just took off the original rusty asbestos tubes and I am installing new accordion tubes and heater boxes from bus depot.
[/img]
