Removing Water Stains/Calcium from Glass **TIP**
JaredB
JaredB is offline
PostPosted: Sun Jun 13, 2004 6:12 pm    Post subject: Reply with quote
ritchiet002 wrote:
Heat and laminated glass? I'm gonna let someone else try that first Smile
The only window that is laminated is the windsheild. all the others are tempered glass. The heat from the steamer is not gonna hurt the tempered glass. But your right stay away from the laminated windsheild if you try the steamer route.
1967 Sunroof.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Tripdaddy
Tripdaddy is offline
PostPosted: Sun Jun 13, 2004 6:08 pm    Post subject: water stain removal... Reply with quote
I do high rise window cleaning for a living...If I were you I'd start with the least abrasive method/chemical first. Try #0000 steel wool in the corner first. Make sure that doesn't leave scratches. It shouldn't we use it on low E and tempered glass all day that are worth thousands of dollars. You can get it wet and dap some joy on the steel wool. The problem that most occurs are abrasive(dirt crystals)that get swirled around on the glass, leaves etch lines. You can see that on all types of glass, and think of all the times we've "scraped" our windows with dirt on them to remove the ice and snow???
2. Anyway the next step if #0000 steel wool doesn't remove the alkalie buildup is #000 steel wool, but that is pushin it. Don't use scrubers like SOS, which are very abrasive or green kitchen cleaning pads. The green kitchen pads also can have a abrasives in them. If you do use a pad it has to be the white pad.
3.If the alkali buildup is great, a razor might need to be used. Try a new one inch razor and buy a little handle to help support it. It will make it easier. You must clean the surface first! Only scrape in one direction!! moving it back and forth can drag particles under the razor and scratch the glass.
4.If those methods dont' work, an acid will be in order. An acid will help neutralize the alkali, bringing the balance back to 7 on the ph scale. We havn't found anything over the counter that works well. You can try to order some acid for a window cleanign supply company. It is designed to use on glass without acid etching the glass. It can be expensive and a little dangerous. The acid made for glass is about 3% by solution and it can still burn you skin etc... At this point you have nothing to lose your trying to restore your glass. Hope this helps. DP
ritchiet002
ritchiet002 is offline
PostPosted: Tue Jun 01, 2004 8:54 pm    Post subject: Reply with quote
Somewhere there is a jar with your name on it!
From now on, I'm gonna connect the dots my own way!______________________________________
JaredB
JaredB is offline
PostPosted: Tue Jun 01, 2004 7:41 pm    Post subject: Reply with quote
Just a thought but maybe you should try steam and a terry cloth towel. I have one of those steam buggy deals. The thing removes most anything from anything. works great on the engine. and cleaning suspension compents. Much easier to repair/replace when you start with a clean area.
1967 Sunroof.
KamperKitJay
BDM Hit Man
KamperKitJay is offline
PostPosted: Tue Jun 01, 2004 7:23 pm    Post subject: Reply with quote
Use rubbing compound (auto paint type) or fine metal polish
http://www.youtube.com/watch?v=1FUDnVrMNnM
ritchiet002
PostPosted: Mon May 31, 2004 11:05 am    Post subject: Reply with quote
AAAAh---now I know! Thank you DubStyle Smile I have a couple of pretty trashed pieces of glass I can try it on.
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Mon May 31, 2004 10:41 am    Post subject: Reply with quote
I just saw it on TV, FLITZ polish
"no more hacking my sig line"
Andrew
Andrew is offline
PostPosted: Mon May 31, 2004 10:30 am    Post subject: Re: Removing Water Stains/Calcium from Glass **TIP** Reply with quote
DubStyle wrote:
Andrew wrote:
DubStyle wrote:
I finally got around to doing the other 3 windows on my Bus. Last time I used steel wool and comet. This time I used a 4.5" Electric DA Sander with a foam pad and Fast Orange hand cleaner. Made light work out of a 2 hour job from the last time. I recommend doing this even more if your windows are out so you get all the stains.
Maybe it's just me, but it seems like that would scratch the hell out of the glass...
Hmmm Andrew do you honestly think I would suggest this if it scracthed your glass. Rolling Eyes Wait as you put it "scratch the HELL out of the glass." Have you ever used Fast Orange hand cleaner? Basically it's abrasive but it starts to break down so it's isn't like using SANDPAPER. I've heard of people using steelwool on calcium build up. So why use elbow grease when you can make it an easier task?
ritchiet002 DA= Dual Action meaning it spins and does an elipse at the same time.
I didn't really think you would, but steel wool on glass seems like it might be bad...
-Andrew
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Mon May 31, 2004 5:25 am    Post subject: Re: Removing Water Stains/Calcium from Glass **TIP** Reply with quote
Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club"
ritchiet002
PostPosted: Mon May 31, 2004 2:20 am    Post subject: Re: Removing Water Stains/Calcium from Glass **TIP** Reply with quote
DubStyle wrote:
ritchiet002 wrote:
Confused Embarassed Question
Don't get it. Confused
Sorry I had to leave to go to a graduation---didn't check my post. I did just an "edit" to my last post---I don't know what a DA grinder is. Embarassed Embarassed Embarassed
Andrew
Andrew is offline
PostPosted: Sun May 30, 2004 8:51 pm    Post subject: Re: Removing Water Stains/Calcium from Glass **TIP** Reply with quote
-Andrew
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Sun May 30, 2004 6:13 pm    Post subject: Re: Removing Water Stains/Calcium from Glass **TIP** Reply with quote
Anthony
SBS #1
SBS #1 on FB
ritchiet002
PostPosted: Sun May 30, 2004 12:21 pm    Post subject: Re: Removing Water Stains/Calcium from Glass **TIP** Reply with quote
Confused Embarassed Question What's a DA sander?
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Fri May 28, 2004 6:52 am    Post subject: Removing Water Stains/Calcium from Glass **TIP** Reply with quote
Anthony
SBS #1
SBS #1 on FB
