Oil Questions
PostPosted: Thu May 21, 2020 9:29 pm    Post subject: Re: Oil Questions Reply with quote
Multigrades are fine.
Please use the dedicated thread above for all oil discussion.
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Thu May 21, 2020 6:04 pm    Post subject: Re: Oil Questions Reply with quote
here ya go read and try to make a decision Wink
https://www.thesamba.com/vw/forum/viewtopic.php?t=220755
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
tandemtwins
tandemtwins is offline
PostPosted: Thu May 21, 2020 5:57 pm    Post subject: Oil Questions Reply with quote
I'm curious as to what the "old-time" VW people have to say about oil in VW'.
A mechanic I used to go to when I lived in Idaho swore by Valvoline 15-40 Heavy Duty oil. The temperature swings in the state possibly warranted a multi viscosity oil... but do VW engines "like" multigrade oils, or a straight single weight oil?
I see in the manual (mine is a 1973) that the oil recommendations for the listed temperature ranges are for single weight oils. Living in Florida, I should be running a 40 weight this time of year, according to the chart.
Is there a difference between multigrade and single grade oils in how they work in an air-cooled engine? Is there a difference between the two kinds of oils; does one handle temperatures better than the other and not degrade as quickly?
Thanks in advance for your thoughts...
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Beetle - Late Model/Super - 1968-up All times are Mountain Standard Time/Pacific Daylight Savings Time
