Multi69s Samba Member
Joined: January 24, 2006 Posts: 5573 Location: Lefty, CA
dustymojave Samba Member
Joined: January 07, 2007 Posts: 5846 Location: Lake LA, Mojave Desert, SoCal
Posted: Tue May 26, 2020 7:00 pm Post subject: Re: Kadrons and a Stinger... way too loud |
I use a 2" "Turbo" muffler, which costs about $27 at many auto parts stores or Amazon or Summit or Jegs. Turbo, not Super Turbo, which has glass pack inside that blows out pretty quick and weighs a ton.
2 - 2" bends, 1 is a 90°, the other is a 180°, both cut to fit, then welded on. The length of straight tube between the collector and the beginning of the bend is because the inventor of the merged collector told me many years ago that with his merged collector or with a Tri Mil BobCat style collector, the 2" collector tube should be 6" long from the collection point to the beginning of the 1st bend for best power and torque. IIRC, the bends came from Jegs. The muffler came from Pep Boys. The muffler got a support welded on to clamp to the bumper so it doesn't break off from vibration and offroad shaking. _________________ Richard
SoCalBajas Member
BFB Samba Member
Posted: Tue May 26, 2020 11:50 am Post subject: Re: Kadrons and a Stinger... way too loud |
turbo _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16807 Location: State College, PA
Posted: Tue May 26, 2020 4:38 am Post subject: Re: Kadrons and a Stinger... way too loud |
No...your stinger is the big thing....Look at something like a Super Trap or other actual muffler that will still give you the look if you still want that, but reduce the noisse. I run one on our buggy and it works well. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
unclebilly Samba Member
Posted: Mon May 25, 2020 8:43 pm Post subject: Kadrons and a Stinger... way too loud |
My 60 Baja beetle has a 1600 DP with kadrons and a stinger (and no idea what else but it will do 100 MPH no problem).
What can I do to make it quieter under slight / full load? It cruises at 60 MPH under low load at 2300 RPM and isn’t too bad.
The noise is definitely intake as well as exhaust. |
