glutamodo  The Android
Joined: July 13, 2004 Posts: 26533 Location: Douglas, WY
Danwvw Samba Member
Joined: July 31, 2012 Posts: 8895 Location: Oregon Coast
Posted: Sun Jun 07, 2020 8:51 pm Post subject: Re: Crank broke |
Nice car! Are you wanting to keep it Original 40 horse engine? It may have messed up the case. Note The 65 40 horse engines had better square boss heads! Something to hang on to if you want to keep it a 40 horse. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3481 Location: Vulcania
Posted: Sun Jun 07, 2020 2:51 pm Post subject: Re: Crank broke |
glutamodo wrote: |
It's kind of unusual to see it happen now, it was certainly an issue in years past, but my opinion is that most of the ones that were going to fail, did so a long time ago and the ones around today are the survivors.
I'm surprised that it seized as a result though. The original engine from my 62 Beetle... got transplanted into a 61 that I sold and later the crank broke. I helped her rebuild the engine after this happened, but the engine was still drivable, it just made a hell of a racket.
Many years later, I had a crank break on me, this one a 1600, while I was driving... again, the engine still ran but did not sound at all well! |
Andy, I'm not surprised. You should have seen the difference in weight on my pistons in my big bore kit. And I'll bet most people think they can install this stuff without equaling the weight and then not taking the rotating assy. parts to the machinist to balance the whole rotating assy. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26062 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jun 07, 2020 12:49 pm Post subject: Re: Crank broke |
Check that the crankshaft has proper radius where the bearing journals meet the webs. Had two cranks break due to no radiuses there, just a sharp 90 degree angle that put all the flex of the crank in those narrow areas, causing cracks.....
The below from the "Without Guesswork" technical booklets you can access thru the "Technical" button above at right.
Left click on image below to bring it up in its own window. Click on image again then to blow it up to easily read it.
_________________ In Stereo, Where Available! |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13948 Location: White Mountains Arizona
Posted: Sun Jun 07, 2020 7:48 am Post subject: Re: Crank broke |
Been there before in July 1975. Driving from Mesa Verde to Kansas City.
It let go near Salina Kansas middle of now where on I-70. Engine still ran but um not to well. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
fl59bug Samba Member
Joined: November 23, 2005 Posts: 2072 Location: North Carolina
Posted: Sat Jun 06, 2020 6:09 pm Post subject: Re: Crank broke |
Yes I've heard about broken cranks when running the big bore pistons. What is hypothesized is that the big bore kit makes the engine feel more powerful and the driver tends to rev it out farther, like past the stock shift points. This pounds out the #2 center main eventually causing the crank to whip around and break at the #2 journal. |
Zundfolge1432  Samba Member
Posted: Sat Jun 06, 2020 4:49 pm Post subject: Re: Crank broke |
Here’s my broken crank. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Sat Jun 06, 2020 4:22 pm Post subject: Re: Crank broke |
any pictures of the teardown? _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
Posted: Sat Jun 06, 2020 3:34 pm Post subject: Re: Crank broke |
Many years later, I had a crank break on me, this one a 1600, while I was driving... again, the engine still ran but did not sound at all well! _________________ Andy T.
"What is Glutamodo, Horror of Toyko, besides total, fiendish, quality-a-you brain!" |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Sat Jun 06, 2020 2:54 pm Post subject: Re: Crank broke |
Big bore alone isn't necessarily the cause; 40hp cranks are known to not hold up to high revs well, a problem more likely to occur when the engine power has been increased. Another common cause is if the crank was reground incorrectly where the radius between the journal and cheek was not maintained.
https://www.thesamba.com/vw/forum/viewtopic.php?t=261915 _________________ 1960 Ragtop w/Semaphores "Inga" |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79652 Location: Sneaking up behind you
Posted: Sat Jun 06, 2020 2:12 pm Post subject: Re: Crank broke |
Stock crank?
If not was it cast or forged? _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
jimwar Samba Member
Posted: Sat Jun 06, 2020 2:11 pm Post subject: Crank broke |
Driving my 65 beetle with stock 1200 motor and the engine seized due to crank breaking. Machine shop asked if I’d been running big bore pistons and I had. He said he had seen it before. Anybody heard that big bore pistons can break the crank? |
