Remove tree sap ?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Sep 23, 2020 2:37 pm    Post subject: Re: remove tree sap ? Reply with quote
When i redid my bathroom, i put and AmerCast tube in. The care instructions specifically say not to use Softscrub.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
74 Thing
74 Thing is offline
PostPosted: Wed Sep 23, 2020 2:34 pm    Post subject: Re: remove tree sap ? Reply with quote
Did you put a light on it after the soft scrub since it is an abrasive. I am sure you swirled and scratched the paint but it you park it under a tree and let sap get all over it you probably don't care about your paint condition in the first place.
lboos
lboos is offline
PostPosted: Wed Sep 23, 2020 1:21 pm    Post subject: Re: remove tree sap ? Reply with quote
Thank you all for the helpful info. Wink
77kafer
77kafer is offline
PostPosted: Wed Sep 23, 2020 10:56 am    Post subject: Re: remove tree sap ? Reply with quote
Glenn wrote:
77kafer wrote:
My wife suggested I use "soft scrub" on a cabriolet that had been sitting under a tree for about 5 years. It worked great.
That WILL scratch the paint. Rolling Eyes
Took the sap off and didn't scratch the paint. Looked great after a wash and wax. I was surprised also. Tried it on an inconspicuous area first.
Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer"
Mr. 010
Glenn is offline
PostPosted: Wed Sep 23, 2020 9:20 am    Post subject: Re: remove tree sap ? Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
77kafer
77kafer is offline
PostPosted: Wed Sep 23, 2020 9:16 am    Post subject: Re: remove tree sap ? Reply with quote
74 Thing
74 Thing is offline
PostPosted: Wed Sep 23, 2020 8:42 am    Post subject: Re: remove tree sap ? Reply with quote
Gel hand sanitizer if you can find it now. It is mostly alcohol and will stay on the vertical surfaces on the sap. You have to put it on the sap and then let it sit for a bit.
If you care about your car don't park under trees or for that matter power lines where birds hang out. More then likely your paint will be etched underneath.
Mark 75 Super Convertible
Mark 75 Super Convertible is offline
PostPosted: Tue Sep 22, 2020 7:44 pm    Post subject: Re: remove tree sap ? Reply with quote
I've got one that I learned from a detail shop years ago. Take a hand towel, and get it wet, and then wring it out until its almost dry. Then, put it in a microwave oven for several minutes until its steaming hot. It will be so hot that you need to wear rubber gloves, and before it cools, rub the towel across the surface. I have a huge maple tree in my back yard, and years ago I let my company store an extra company car at my house, and after a few months it looked like a glazed donut! My local car wash recommended this, and it worked great. Best part, it's free!
Mr. 010
Glenn is offline
PostPosted: Tue Sep 22, 2020 8:10 am    Post subject: Re: remove tree sap ? Reply with quote
http://kleanstripauto.com/products/prep-all-bug-tar-remover-aerosol
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
sgmalt46
sgmalt46 is offline
PostPosted: Tue Sep 22, 2020 7:35 am    Post subject: Re: remove tree sap ? Reply with quote
I have used WD40 with good results .
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG
Big Bull Shooter
Big Bull Shooter is offline
PostPosted: Tue Sep 22, 2020 7:11 am    Post subject: Re: remove tree sap ? Reply with quote
Epilog79 wrote:
I second the nod to 90% rubbing alcohol. I have used it for years as I have 4 fir trees along my driveway. We call it sap season. Only problem is trying to find any at the stores during this Covid time. Seems everyone bought it all up to make there own hand sanitizer.
Hand sanitizer works good for removing sap!
Epilog79
Epilog79 is offline
PostPosted: Tue Sep 22, 2020 7:03 am    Post subject: Re: remove tree sap ? Reply with quote
2type2
2type2 is offline
PostPosted: Tue Sep 22, 2020 4:27 am    Post subject: Re: remove tree sap ? Reply with quote
I once questioned a professional car detailed and the answer was "90% rubbing alcohol". Sure enough, the cheapest and the best. Works great on pine sap.
"A life of peace and happiness depends on your own gratefulness"
lboos
lboos is offline
PostPosted: Tue Sep 22, 2020 3:43 am    Post subject: Remove tree sap ? Reply with quote
I bought a 71 bug that has been parked under a tree for a long time, any idea how to remove the tree sap from the paint "that works" ? Thanks.
Did a search, could not find anything.
