airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13621 Location: West Coast, USA
Posted: Wed Jul 28, 2021 6:58 pm Post subject: Re: Buying a Bay Window |
Ryan! How is your idle holding up after our little twist Monday night?
When we talked about cold start idle speed, this is the screw I wanted to point at but didn't want to get my white shirt dirty.
On a stone cold engine, remove the air filter. Observe choke plates. Tap the throttle one time and make sure the choke plates close slightly on a warm day. Snugly on a cold day. Observe the gap at the screw tip (shown) once the choke is adjusted correctly. Close the gap and go approximately one turn in. Start the engine, and be ready to turn the screw up or down to get an idle that fires on all four cylinders, no higher. It may take a day or two to get it perfect if your choke is out, or if your carb is more sensitive than others.
See you on the road,
Robbie
_________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53179 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jun 07, 2021 7:38 am Post subject: Re: Buying a Bay Window |
If it's there it's well hidden.
Use caution when replacing the rocker assembly, those nuts strip super easy, 9' lbs torque IIRC. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
crownline Samba Member
Joined: September 10, 2010 Posts: 613 Location: Northwoods of WI
Posted: Mon Jun 07, 2021 6:26 am Post subject: Re: Buying a Bay Window |
Is it just me because I don't see the push rod tube retaining spring in that picture.  _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
timvw7476 Samba Member
Posted: Sun Jun 06, 2021 10:03 pm Post subject: Re: Buying a Bay Window |
not a huge deal. You will be pulling the left rocker assembly. The nuts are right there, 11mm or so. Take off the rocker shaft for that cylinder. The snapped valve adjuster screw remnant will thread right out the backside of the threaded boss.
There is one 'spring' you need to set right when you reassemble, the pushrod tube retainer spring that keeps the tubes in place. Make sure that spring is pressing IN on the bottom lip of the tubes. Not UP at you pushrods. |
theguyryry Samba Member
Joined: March 31, 2021 Posts: 100 Location: Portland, OR
Posted: Sun Jun 06, 2021 7:38 pm Post subject: Re: Buying a Bay Window |
Hey y'all, just wanted give an update on how bubba and i are doing, along with post a question. hoping for you the hive mind to tell me how screwed i am...
the update - I managed to get bubba back to Portland, after an arduous journey on the back of a truck. I tried using Easy Auto Ship, but they under quoted me, so none of the available truck drivers took the bid. I ended up paying $2400 to get it shipped from Florida to Portland... But she made it! Only a couple scratches on the roof from the drive, and a weird hole in the z-bed cover. I'd have been more upset if I wasn't planning on tearing that out this summer. She's been chugging along, no major paint points and honestly just having a blast driving her around.
the question - I've been going through the Muir book, and finally had some time this weekend to dive in and try my hand at basic maintenance. I was planning on doing the valves, compression check, general clean up, and I bought some parts I was going to install (mostly cosmetic stuff). I'd already done an oil change in florida (less than 100 miles ago) so I was going to skip that. Well anyway, I get the to the valve adjustment, and things are off to a rocky start. The PO (or whoever was maintaining it) used adhesive on both sides of the valve cover gaskets, so I spent about 3 hours scraping them clean. Oh well, I won't have to do that again. I get to adjusting the valves, move the motor to TDC, valve adjustments went great. I adjust the valves to BDC, go to loosen valve adjustment nut, and the bolt sheers right off.
How screwed am I? it looks like you can buy the bolts online, none of the local parts stores had them. Can someone direct me to a video or description on how to remove those valves adjustment bolts without messing with the springs? do i have to drop the motor? I'm assuming I can't start / drive bus until I get that replaced, right? |
HoboBus Samba Member
Joined: December 29, 2016 Posts: 350 Location: Not Key West, unfortunately.
Posted: Mon May 03, 2021 5:32 am Post subject: Re: Buying a Bay Window |
Excellent. Oil light is good.
Moral of the story: You never know what you're gonna find in a vehicle that's been rumbling around for almost 50 years, with who knows how many owners.
. _________________ Salt air it ain't thin, it'll stick right to your skin,
it'll make you feel fine. Makes you feel fine.
And I wanna be there. -- Jimmy Buffett
Just a beach-oriented camping Hobo with a bus. |
Posted: Sun May 02, 2021 6:22 pm Post subject: Re: Buying a Bay Window |
Update on my wiring fiaso...
I went to the meetup in Pensacola this weekend. Awesome group of people. The most air cooled VW's in one place that I've been. Don (the host) and some other people helped me figure out what was going on. Turns out, the PO rewired the dash so that the positives and negatives were flipped... what a cluster... Don ended up helping me rewire all of that, and yelled at me for my terrible job in engine bay .
Long story short, the oil light works now! the turn signal lights are a bit weird (always on), but I can live with that for now. I managed to make it to and from Pensacola with no mechanical issues! I did, however, get pulled over for not registering the bus in FL. Even after telling the cop that I'm only gonna be here for another week, i ended up getting a citation. Now I have a court date for the same week I'm back in Portland... Gonna see how that goes, lol.
Thank you to Don, Tbob, busdaddy, and everyone else that's helped me so much already! Next up, learning how to do my timing and adjust my valves! Hopefully that'll end up going better than my soldering .
jlrftype7 Samba Member
Posted: Thu Apr 29, 2021 8:30 pm Post subject: Re: Buying a Bay Window |
| theguyryry wrote: |
| HoboBus wrote: |
You really need a simple volt-ohm-meter. Even the $2.99 one from Harbor Freight. You need to confirm 12v+ at one terminal of the bulb socket in the dash, key on. Confirm that the bulb is good and the socket is good, so the 12v+ is going through the bulb and into the other wire of the socket.
Then confirm that the wire you're working with in the engine compartment is the same wire coming from the bulb.
Then confirm that the new sensor in the engine is working, by confirming connection of the terminal connector to ground when the motor ISN'T running, and NO connection to ground when the motor IS running.
Then the light should work.
Seems like a lot, but it's really not.
There's a lot off things that could be the culprit:
No power at the bulb.
Bulb Socket dirty or broken.
Bulb bad.
Wrong wire in the engine compartment.
Keep at it!
I did end up splurging and bought the $39 multimeter from Autozone. I almost definitely paid way too much for it, and I have no idea how it works, but I got it to show 12.5 volts when connected to the terminals on the battery. If I have time tomorrow I'll go through these steps to find the culprit. Question:
How do I confirm ( using multimeter ) the wire I'm working with in the dash is the same as the engine compartment, other than following the bentley manual and color coded wires?
I'm sure I'll have more tomorrow...  |
. With a long enough jumper wire, you perform a continuity test using the OHM function on your new meter. Google testing Open Circuits or Performing Resistance Checks with a Multi Meter.
The test leads on any meter are too short to check front to back on a vehicle, so you make or buy a jumper wire to span the distance . Added screen shot of common tool with alligator clips already installed that many shops and techs use, since it’s easy to unreel, and rewind the wires back up with this premade set-up.
Here you go, no VW toolbox should be without one of these.
They tend to come in either 10 foot rolls or 30 foot rolls, 2 or 3 wire versions for either length.
You gently pull on both wire ends to spool the wires out, then to rewind, you hold the bottom and turn the top half, or similar.
Most of these are light gauge wire, so you can’t do power substitution feeds on circuits that pull a lot of amps , but for resistance or ohm checks, 18ga wire is fine.
Much easier than unraveling a coil of wire you bought at the auto parts store and adding clips to both ends.
_________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Thu Apr 29, 2021 7:31 pm Post subject: Re: Buying a Bay Window |
| HoboBus wrote: |
Bulb bad.
Keep at it!
Posted: Thu Apr 29, 2021 3:10 pm Post subject: Re: Buying a Bay Window |
Bulb bad.
Keep at it!
Posted: Thu Apr 29, 2021 2:21 pm Post subject: Re: Buying a Bay Window |
| Tbob wrote: |
| Hey, are you still in Pensacola? If so, there is another tech session at Don Doroughs, on Longleaf,at 10:00 Saturday. Lots of bus guys will be there to help with questions if you want, although you got some great guys answering your questions here! The tech session is informal, guys just come and bring their cars and we try to get things resolved. I will be there with my 73, if you come, my name is Tom. Come find me if you want. |
Not quite pensacola, I'm down in Niceville. I was planning on going if I get enough confidence with bubba! haha. I'm a little spooked driving it with the oil light not working. |
Tbob Samba Member
Joined: May 26, 2007 Posts: 447 Location: Pensacola, Fl.
Posted: Thu Apr 29, 2021 1:59 pm Post subject: Re: Buying a Bay Window |
Hey, are you still in Pensacola? If so, there is another tech session at Don Doroughs, on Longleaf,at 10:00 Saturday. Lots of bus guys will be there to help with questions if you want, although you got some great guys answering your questions here! The tech session is informal, guys just come and bring their cars and we try to get things resolved. I will be there with my 73, if you come, my name is Tom. Come find me if you want. _________________ 1969 Deluxe, owned since 1973
1973 Westfalia, owned since 1983
1980 Westfalia, watercooled conversion
1985 Westfalia, stock!
1986 Westfakia, Audi I-4 conversion
A couple of trucks and a couple of Jeeps |
Posted: Thu Apr 29, 2021 9:35 am Post subject: Re: Buying a Bay Window |
| busdaddy wrote: |
| theguyryry wrote: |
| busdaddy wrote: |
| That was added by whoever installed the Weber, the oil wire doesn't supply power. Follow the black wire that one is teamed up with on the coil up to the roof of the engine compartment, sooner or later it'll become a thin harness near the booster fan mount, the blue/green wire is in that. |
Alright, I've followed this black wire, and after cutting back some of the harness, I found and connected the new sensor to the blue/green wire. Going to turn the ignition, and the oil light still doesn't turn on. the bulb looks ok... is there anything else I can check? |
Do the rest of the idiot lights work?, specifically the charge light?, if they do the bulb is the #1 suspect. |
the generator / alternator light works, although it doesn't seem to turn off... still gotta figure out why that's happening. I do have more bulbs on the way, waiting for busdepot to ship them out. |
Posted: Thu Apr 29, 2021 9:29 am Post subject: Re: Buying a Bay Window |
| theguyryry wrote: |
| busdaddy wrote: |
Do the rest of the idiot lights work?, specifically the charge light?, if they do the bulb is the #1 suspect. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 29, 2021 9:20 am Post subject: Re: Buying a Bay Window |
| busdaddy wrote: |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15410 Location: Syracuse, NY
Posted: Wed Apr 28, 2021 2:52 pm Post subject: Re: Buying a Bay Window |
they removed the oil light switch because either
it leaked oil and they did a long term temp fix by plugging it
it constantly flickered and the plug in it's place is so much less stress in the mountains at night
or they're just plain dumb, that scenario will come to light with other 'repairs' _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
Posted: Wed Apr 28, 2021 1:43 pm Post subject: Re: Buying a Bay Window |
| theguyryry wrote: |
| Could it be that the PO removed the oil sensor because they needed a 12v connection for the electric choke on the weber? |
If they did that, it was a bad idea.
Yes, that is your electric choke. Power for the choke should come from a new separate wire, direct from ignition coil +, to the terminal on the choke. If that's not how it's wired now, wire it that way with a new wire.
Keep in mind that the oil pressure sensor does need 12v+, but it needs to come through the bulb in the dash, like we talked about. Not just regular battery power like the electric choke uses. _________________ Salt air it ain't thin, it'll stick right to your skin,
Posted: Wed Apr 28, 2021 1:40 pm Post subject: Re: Buying a Bay Window |
That was added by whoever installed the Weber, the oil wire doesn't supply power. Follow the black wire that one is teamed up with on the coil up to the roof of the engine compartment, sooner or later it'll become a thin harness near the booster fan mount, the blue/green wire is in that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Apr 28, 2021 12:56 pm Post subject: Re: Buying a Bay Window |
So, taking a look at it again... It looks like there's a green wire that goes from the ignition coil to the weber carb. Could it be that the PO removed the oil sensor because they needed a 12v connection for the electric choke on the weber??
wire being touched in both photos is the same wire. one end goes to the ignition coil, the other goes to what I assume is the electric choke on the aftermarket weber carb.
Ordered an oil pressure sender, should be here by EOD. Also ordered some other stuff from busdepot... extra bulbs, dipstick oil temp sender, fuses, and a replacement fuse box cover, cause it looks like mine is missing. |
Posted: Wed Apr 28, 2021 11:19 am Post subject: Re: Buying a Bay Window |
I'd be careful with loctite - You want to be able to get it back out easily if it fails.
Also, don't get any goop in the hole on the sensor, could ruin it.
If anything, maybe a little rtv on the male threads. Just a little.
If you don't have a multimeter now, consider getting a nice one, that includes tachometer, dwell for checking your points, etc. Actron has a decent one that's like $40 and is what I bought.
As for the threads, I guess I'd take out the bolt and see how it looks. If the threads on the bolt look ok, and measure 10mm across, the hole is probably ok. If the threads on the bolt look like crossthreaded crap.... the hole will need closer review. _________________ Salt air it ain't thin, it'll stick right to your skin,
