KeremPeya Samba Member
Posted: Tue Apr 20, 2021 10:33 am Post subject: Re: Drop Spindes HELP |
sportin-wood wrote: |
I think your bug looks great in both before & after pics!  |
Thank you so much!  _________________ 65' Bug
70' T2 Westfalia
72’ Beetle Convertible in the works
66' Karmann Ghia in the works |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2255 Location: Texas
Posted: Tue Apr 20, 2021 10:27 am Post subject: Re: Drop Spindes HELP |
I think your bug looks great in both before & after pics!  _________________ Dave
1966 Bug project
1973 Thing project
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Joined: August 31, 2013 Posts: 13304 Location: North Carolina
Posted: Tue Apr 20, 2021 9:39 am Post subject: Re: Drop Spindes HELP |
Umm, the mechanic ordered the wrong kit, this is on them to make it right. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Apr 20, 2021 7:11 am Post subject: Drop Spindes HELP |
I recently did a disc brake conversion (front and back) on my 65' but there is a problem. My mechanic ordered the wrong kit and got the ones with the drop spindles! When installed the car dropped like BAM! (which should be expected with drop spindles). My car was already slightly lowered from the beams so that made the situation even worse. In order to compensate for that, we changed the beam to an adjustable beam (not narrowed), which helped but not enough. Now I am running 175/60 R15s up front and 185/65 R15's on the rears (compared to 165/80 R15's overall) which also give the car a rake that I don't like. The rears don't really bug me *no pun intended* but the fronts are tiny! With the port-a-walls, they look even smaller! Also, I am not liking the ride disadvantages with the small tires and lower ride height.
One other problem I have is that I live in Turkey. Importing parts take a long long time and a load of money. My mechanic suggested, as a solution, to take the spindles to a machining shop and have them converted to a normal ride height spindle. This won't be done on my car, it is an experiment that will be done on other disc brake drop spindles which won't affect me so I won't be spindelless . Is this a good idea? Also, I have been on the internet searching for normal disc brake spindles but there are none! Nobody sells them alone and the ones that I found don't fit the 65' model year.
What do you think I should do to return my car to its stock ride height and have taller tires? Are there any possible solutions that you know? I would also love it if you could suggest anyone who sells normal spindles for disc brake conversions that fit 65'.
Here are the photos:
Before:
After:
70' T2 Westfalia
