Fuel pump inlet/outlet (photo)
Eric&Barb
Eric&Barb is offline
PostPosted: Fri May 07, 2021 7:43 pm    Post subject: Re: Fuel pump inlet/outlet (photo) Reply with quote
markeaton wrote:
Is that vacuum port on the intake just below the carb plugged off? If not, do plug it or it will run lean and too hot.
In Stereo, Where Available!
markeaton
markeaton is offline
PostPosted: Fri May 07, 2021 8:46 am    Post subject: Re: Fuel pump inlet/outlet (photo) Reply with quote
Thank you.
sgmalt46
sgmalt46 is offline
PostPosted: Fri May 07, 2021 7:53 am    Post subject: Re: Fuel pump inlet/outlet (photo) Reply with quote
the one your pointing to goes to the carb. Wink
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG
markeaton
PostPosted: Fri May 07, 2021 7:10 am    Post subject: Fuel pump inlet/outlet (photo) Reply with quote
Do the old style fuel pumps (like Peirburg et.al.) have the line from the tank lead to the top line (my finger is pointing)?
Or do they vary in and out?
