Weird horn and hi-beams issue
bhartwell59
bhartwell59 is offline
PostPosted: Mon Jun 28, 2021 7:22 am    Post subject: Weird horn and hi-beams issue Reply with quote
First off, I always drive with my headlights on.
However, after driving 45+ miles (doing 70) on a 95 degree, humid day I found that my horn did not work, and when pressed, the hi-beams would click on.
The next morning everything was back to normal... horn worked correctly and the hi-beams worked via the steering column stalk.
I believe it's the turn signal switch. The heat did something (heat expansion led to a short, etc).
I'm all ears tho!
'74 Zambezi green Ghia vert, autostick, 103k
'87 Jeep Wrangler, 4.2, 334k
