pdb27 Samba Member
Joined: April 22, 2015 Posts: 36 Location: Lafayette, IN
Posted: Mon Apr 29, 2024 10:27 am Post subject: Re: Mystery oil leak in back of 40 hp motor |
Quote: |
Whoa!! If it was one of his race engines all sorts of things could be going on inside it. |
True statement. As of today the rings, pistons, cylinders, valves, and springs in the motor are from a big bore kit I installed after less than 2k miles, which have sealed up nicely over the last 10k miles, so blowby isn't currently an issue. However, I can only speak about the stuff I replaced. Before 2k miles the motor had two valve springs snap and two rocker spring washers break into pieces, which upon inspection all had a lot of pitting to act as stress concentrators. Pitting is caused by rust, which itself is caused by water and time, so my imagination paints a plausible picture: guy sells motors to fund a racing habit, guy has a garage with lots of parts accumulated over the years, guy cobbles together what he's got and sends it out the door. It's easy for me to believe that there are worn and hard-run parts inside my motor.
@KTPhil - Thanks for the tip. I didn't know this and will read up about it. |
wdfifteen Samba Member
Posted: Mon Apr 29, 2024 8:50 am Post subject: Re: Mystery oil leak in back of 40 hp motor |
pdb27 wrote: |
One more update to this thread after getting to know the motor for about 12,000 miles, |
Thanks for the update. It's great to find out how things turned out.
pdb27 wrote: |
I bought it from a Formula-Vee racer. |
This was 50 years ago, so rules may have changed. The rule was you had to use stock pistons in an FV. Some (maybe most?) guys would hone the crap out of the cylinders to get a handful of extra ccs of displacement. They had to knurl the piston skirts to keep them from rocking around in the cylinders. This left the top of the piston and the rings fitting very loosely in the cylinder. They didn't worry too much about the extra leakage past the rings that this caused.
What this can add up to is a lot of blowby past the rings, which would cause pressure in the crankcase, which would cause all manner of oil leaks.
You might find some interesting things inside that engine. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34149 Location: Conejo Valley, CA
Posted: Mon Apr 29, 2024 7:58 am Post subject: Re: Mystery oil leak in back of 40 hp motor |
If the endplay can be cured by re-shimming the flywheel, you don't need an engine rebuild.
If the bearing itself is loose in the case, then yes, case machining is needed. _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback
pdb27 Samba Member
Posted: Mon Apr 29, 2024 7:21 am Post subject: Re: Mystery oil leak in back of 40 hp motor |
One more update to this thread after getting to know the motor for about 12,000 miles, and after attending several VW shows and speaking with old-timer mechanics possessing enjoyable esoteric knowledge about air-cooled engines.
First, there is likely something going on internally with the old 40-horse that is contributing to the oil seepage past the crankshaft pulley. I have noticed an omni-present ticking in the motor, even after adjusting the valves, and it is coming from inside the case (confirmed by listening on one side, then the other, then underneath, and then with the needle-stethoscope thingy). A couple of the aforementioned VW savants believe I might have too much crankshaft end play, which matches the ticking noise, the oil leakage, and the overall condition of the motor when I bought it from a Formula-Vee racer. Short of a rebuild, it is what it is; nothing I can do until it starts to bleed to death on some future grey day.
Second, I've got the engine to a daily driver condition where the leaks don't trouble me much. Stock air cleaner on top, slightly thicker oil (Royal Purple 15W-40 with zinc), keeping the level to between min-and-max markings, limiting my speed to 60 mph, and watching the throttle on hot days all adds up to a driveable bug. If I had it to do over again I would probably paint the engine black, rather than red, because all those little heat-shedding tricks add up. Red looks great, but for a daily driver I would have selected the plain-but-functional black paint job.
So, that's the cherry on top for this thread, based on all I've learned. Another hat tip to thesamba.com feedback providers, and I hope this helps you future readers. |
pdb27 Samba Member
Posted: Tue Sep 28, 2021 12:12 pm Post subject: Re: Mystery oil leak in back of 40 hp motor |
I do have a stock oil cleaner, but it's currently not usable because the breather hose opening on the right hand side has been pinched shut. There is a "Volkstoberfest" in Indy on 9 Oct that includes a parts swap, so I'll see if I can't score one when I'm down there. Several threads have recommended using the stock cleaner, and I think it will even help out with my crankshaft pulley leakage, so I'm planning to make that move. |
KTPhil Samba Member
Posted: Mon Sep 06, 2021 12:36 pm Post subject: Re: Mystery oil leak in back of 40 hp motor |
Those low profile air cleaners do not give space for the fuel fog above the carb at certain rpms. It can wet the filter element, and even draw oil in from the breather to saturate it, and then it leaks down. Do you have a stock air cleaner you can try substituting? The internal tube acts to hold the fog, and of course it doesn't mind getting oil in its fibers. _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
vwoldbug Samba Member
Posted: Sun Sep 05, 2021 9:21 pm Post subject: Re: Mystery oil leak in back of 40 hp motor |
Can you look for a small rust hole in the oil filler . |
pdb27 Samba Member
Posted: Thu Sep 02, 2021 6:02 am Post subject: Re: Mystery oil leak in back of 40 hp motor |
This morning I finally had the chance to run the bug down the interstate for an hour, and after popping the decklid to take a look ... (drumroll) ... it was dry! Mostly. Dry enough for my expectations. It looks like the culprit was an overfilled crankcase due to relying on an uncalibrated dipstick to tell me when to stop adding oil. Lesson: only dipsticks rely on just the dipstick.
The engine even sounded better while purring down the interstate. I think I'll change the generator stand and fuel pump gaskets one last time to clean those up, and then call it good. Many thanks to the commenters on this thread!
pdb27 Samba Member
Posted: Tue Aug 24, 2021 2:44 pm Post subject: Re: Mystery oil leak in back of 40 hp motor |
cyclehobby wrote: |
During an oil change, I put in EXACTLY the 2.5 quarts needed and the dipstick showed oil right in the middle of the low and high marks. I filed a mark right there so I know the right amount of oil is on that spot and I've been very leak free for years. |
This is an idea that I will definitely copy. It's true that I was relying on the dipstick without monitoring how much was going in. Are there passages that can capture and hold enough oil that sometimes 2.5 quarts would be too much? So far the notion of an overfilled crankcase is the closest thing I've encountered to a smoking gun.
Also, I thought I might get a question about the oil additive. I have read nothing on the topic yet, and I haven't owned enough VWs to know what a healthy engine should sound like, but I was curious to know whether one of those friction-reducing additives would quiet down the tapping noises that seem to come from everywhere. Didn't make a difference, and the engine is running GREAT, so I guess I didn't need it after all. All part of the learning process. |
cyclehobby Samba Member
Joined: August 29, 2013 Posts: 156 Location: North Jersey
Posted: Tue Aug 24, 2021 12:16 pm Post subject: Re: Mystery oil leak in back of 40 hp motor |
All the responses from the Samba are excellent possibilities for the cause of your oil leak. But your last post has me intrigued. You said you changed the oil and added oil to put it in the proper spot on the dipstick, but not all the way to the top.
Is it possible you have an incorrect dipstick and you're overfilling the crankcase each time? Too much oil can cause leaks in certain ways. Your oil breather, the crank pulley, the main seal. All can spew oil if there's too much volume and associated pressure. I would think that at high speeds, extra oil slinging around could find it's way out in a number of places.
In my car, I found that filling the crankcase until the highest mark on the dipstick was way too much oil. During an oil change, I put in EXACTLY the 2.5 quarts needed and the dipstick showed oil right in the middle of the low and high marks. I filed a mark right there so I know the right amount of oil is on that spot and I've been very leak free for years.
The rather low oil capacity of these motors also means that when you have a full crankcase and add some sort of oil additive, you're potentially raising the oil level too high. Not sure what to tell you about additives (that may be a separate discussion), but if you've had issues with some of the parts used on your engine rebuild, the dipstick could be the culprit. _________________ 1967 Beetle
Northern NJ |
pdb27 Samba Member
Posted: Tue Aug 24, 2021 11:51 am Post subject: Re: Mystery oil leak in back of 40 hp motor |
Quick update on this thread: I haven't yet driven it on the Interstate for an hour, which is typically when the oil leak is most obvious, but I've been watching it closely enough for the last 2 weeks in mixed driving around town to say that the leak is still there. Very low level, but definitely present.
Crankcase oil level does seem to play a role. During troubleshooting I changed the oil and refilled to between the low and high marks on the dipstick, and at that level there was very little leaking. A few days ago I poured in an oil additive that brought it up to the high mark on the dipstick, and afterwards I could see evidence of more oil coming from behind the pulley. I'll drain a bit back out and see if the leak abates.
My intention to try a stock air cleaner with better negative pressure is on pause, because the one I have has the breather port pinched shut and sealed. Not sure why anybody would do that, but I'll try to bang it back open at some point when I have the time.
I haven't put the stock pulley back on because the leak was present with both pulleys, and a visual inspection showed them to both have clean grooves. Maybe later.
Final comment is that the oil appears to be most noticeable on the tin to the right of the pulley near the dipstick, and I've read in other threads that some owners will put string up there to help seal in oil splashing up from the crankcase. I'll give that a go and see what happens.
So maybe this wasn't such a quick update, but the quick summary is that the oil leak persists and I'm learning bit by bit. When the oil leak is addressed I'll add a closing write-up to the post. Thanks again to all commenters for your help. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24868 Location: Olympia Wash Rinse & Repeat
Posted: Fri Aug 13, 2021 7:24 pm Post subject: Re: Mystery oil leak in back of 40 hp motor |
pdb27 wrote: |
I'm willing to try it. What will this do? |
If the problem ceases after the change, that shows the aftermarket pulley is the cause.
This is called the process of elimination, and best done one part at a time. _________________ In Stereo, Where Available! |
pdb27 Samba Member
Posted: Fri Aug 13, 2021 6:39 pm Post subject: Re: Mystery oil leak in back of 40 hp motor |
Eric&Barb wrote: |
Clean up the stock pulley, and you can sand the inner bore so it just slides onto the crankshaft. Then install it to see if the oil leak goes away. |
To wrap up the day I studied up on crankcase ventilation, checked compression on the rings (they ranged from 128-148 psi), cut a couple inches off the breather hose to shallow out the upward slope, and changed the oil but didn't fill it all the way back to the top line of the dipstick. We'll see what this does.
The distributor does have the oil seal. I have an old stock air cleaner that needs refurbishment, and might try that later to pull more negative pressure on the top of the breather.
Wish I had found a smoking gun! But maybe all these little changes will add up to the right fix. Appreciate the ideas, and I'll keep this string posted. |
Posted: Fri Aug 13, 2021 12:26 pm Post subject: Re: Mystery oil leak in back of 40 hp motor |
Clean up the stock pulley, and you can sand the inner bore so it just slides onto the crankshaft. Then install it to see if the oil leak goes away. _________________ In Stereo, Where Available! |
1960vw Samba Member
Joined: May 05, 2008 Posts: 212 Location: tax everything, liberal ca
Posted: Fri Aug 13, 2021 10:10 am Post subject: Re: Mystery oil leak in back of 40 hp motor |
Another spot , though rare, is from base of distributor, O-ring on shaft going into case. You've checked the common culprits. Hope you find it! |
pdb27 Samba Member
Posted: Fri Aug 13, 2021 9:28 am Post subject: Re: Mystery oil leak in back of 40 hp motor |
Took the day off to begin trouble-shooting, with no clear smoking gun yet (that i can tell). Pictures below.
Oil level OK, right under the top line. Took the breather off and ensured it was clear by blowing through it; cut a new gasket and cinched it back on tightly. Popped off the air cleaner top and took a photo of the oil condensate; there wasn't much, but it does appear to be breathing fine. Removed pulley and compared to the stock version - both were the same size and had clean grooves (and both experienced the same leak, so those grooves aren't a likely contributor). Gasket on the cap was very oily, but sealed up fine.
It was difficult to get a good photo of the crankshaft area with the engine still in, but I attached the best one of the bunch. I could not tell whether there was an oil slinger in place, but there was a washer-like thing in there that I could move with a long screwdriver. It looked flat to me, so I can't say whether it's cupping in or out. It is rusty, like many of the old parts my engine builder put on the bug (separate story).
Anybody have ideas based on these pictures? Sand seal is the next step?
RWK Samba Member
Posted: Thu Aug 12, 2021 5:01 am Post subject: Re: Mystery oil leak in back of 40 hp motor |
Also check that the gen tower to breather/oil filler nut is tight and a gasket is ok. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
pdb27 Samba Member
Posted: Thu Aug 12, 2021 4:38 am Post subject: Re: Mystery oil leak in back of 40 hp motor |
Zwitterkafer wrote: |
If it is the pulley, there should be a "racing stripe" of oil under the back of the decklid. |
@Zwitterkafer: racing stripe confirmed. Once you told me to look for it, there it was as plain as you please.
I'll jot all these tips on the clipboard, do some exploratory surgery on Saturday, and update this post with what I find. |
Posted: Wed Aug 11, 2021 2:01 pm Post subject: Re: Mystery oil leak in back of 40 hp motor |
Check that the oil groove in the pulley is not full of dirt or is even there. Some pulleys are are made for sand seal only.
Better to get the stock dog house crankshaft pulley that is bigger for more gen and cooling fan RPMs. That in turn will make the engine run cooler, and last longer. _________________ In Stereo, Where Available! |
1960vw Samba Member
Posted: Wed Aug 11, 2021 1:21 pm Post subject: Re: Mystery oil leak in back of 40 hp motor |
Check the gasket on the oil fill cap. I would also clamp the bypass hose at both from oil neck to air cleaner. Nice looking engine! |
