Torque for Manifold Nuts
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Sep 01, 2021 4:07 pm    Post subject: Re: Torque for Manifold Nuts Reply with quote
2067Bug wrote:
Thanks Glenn – I checked my available torque source material and could not find this one. I use a bicycle torque wrench that works great for ranges from 2-10 ft-lbs, i.e., oil plate nuts.
I just double checked in the Without Guesswork handbook and it's 6ft-lbs.
I also use a 1/4 drive torque wrench that I use on carbon fiber bikes.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
2067Bug
2067Bug is offline
PostPosted: Wed Sep 01, 2021 3:50 pm    Post subject: Re: Torque for Manifold Nuts Reply with quote
Mr. 010
Glenn is offline
PostPosted: Tue Aug 31, 2021 4:33 pm    Post subject: Re: Torque for Manifold Nuts Reply with quote
9ft-lbs, same as oil pump.
Actually it's 6ft-lbs, same as strainer plate.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
2067Bug
2067Bug is offline
PostPosted: Tue Aug 31, 2021 4:08 pm    Post subject: Torque for Manifold Nuts Reply with quote
What is the torque setting for the nuts holding down the manifold on the heads for a stock 36 hp engine?
Thanks
