Rocker Arm Shimming
evanfrucht
evanfrucht is offline
PostPosted: Sat Nov 06, 2021 7:48 pm    Post subject: Re: Rocker Arm Shimming Reply with quote
You want if offset... it spins the valve stem that way, wears better. Resist all temptation to get them centered.
Shim end play for rocker arms to loose zero.
1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder )
earthquake
earthquake is offline
PostPosted: Sat Nov 06, 2021 5:02 pm    Post subject: Re: Rocker Arm Shimming Reply with quote
You can get 18mm shims at Mcmaster-Carr...
https://www.mcmaster.com/metric-shims/ring-shims-7/
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
jeffrey8164
jeffrey8164 is offline
PostPosted: Fri Nov 05, 2021 3:15 pm    Post subject: Re: Rocker Arm Shimming Reply with quote
Don’t grind the rocker. If you have to grind anything grind the blocks. You can use regular sandpaper on a piece of glass to make sure it’s flat.
Also, I’ve found that I had to use some of the stock shims as they are thinner than the ones that come in the solid shaft kits.
Volkswagen!
(Compression 8.7:1)
ept000
ept000 is offline
PostPosted: Fri Nov 05, 2021 5:48 am    Post subject: Re: Rocker Arm Shimming Reply with quote
ZEKE65 wrote:
Some look pretty good, and others not. I would try to get the ones off closer to center. If I remember right, you are supposed to aim for 1mm ( .040" ) offset between the adjuster and the valve centerlines.
Hmmm, I didn't know it was that tight, To get to .040" I will definitely have to sand down the sides of the rockers.
Mikedrevguy
Mikedrevguy is offline
PostPosted: Thu Nov 04, 2021 5:27 pm    Post subject: Re: Rocker Arm Shimming Reply with quote
I’ve found that torquing the rockers down can have an effect on the end product.
Maybe add some nuts?
74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!!
ZEKE65
ZEKE65 is offline
PostPosted: Thu Nov 04, 2021 1:01 pm    Post subject: Re: Rocker Arm Shimming Reply with quote
1965 VW Sedan, 1968 C10 Step BB, 99 C5
ept000
ept000 is offline
PostPosted: Wed Nov 03, 2021 5:47 pm    Post subject: Rocker Arm Shimming Reply with quote
How far off center is too far? I set up the one rocker arm that has no more room for adjustment without grinding down the side, and shimmed the rest to match as close as possible. I want them off center to help rotate the valve, I just want to be sure they aren't TOO far off center. I'll probably get them a little closer to even with each other once I start tightening everything down and set the final gap. But for now, how does this look?
