mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Wed Jan 12, 2022 3:11 pm Post subject: Re: When a warranty is not what it says |
| gerick the walmart greeter's problem. |
CanStan Samba Member
Joined: October 16, 2005 Posts: 1117 Location: Calgary, AB
Posted: Wed Jan 12, 2022 3:04 pm Post subject: Re: When a warranty is not what it says |
| Erik G wrote: |
| First of all F-Walmart. If you shop at Walmart you are part of the problem |
What problem? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24323 Location: NYC/Upstate/ROW
Posted: Wed Jan 12, 2022 12:33 am Post subject: Re: When a warranty is not what it says |
Itโs such a small cost of ownership of running a car itโs not worth the posts about it.
Three year life worst case , $50 per year ?
Have a good 10 amp charger and a maintainer for a light used car and itโs a 5 year battery, $30 per year
( may not apply in those hot places the Creator tries to warn you not to live there by sending scorpions) _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
Lind Samba Member
Joined: November 06, 2000 Posts: 10265 Location: idaho
Posted: Tue Jan 11, 2022 10:35 pm Post subject: Re: When a warranty is not what it says |
I get my 12v batteries at the local junkyard. $43 exchange with a full 1 year warranty. If it takes a dump, they will replace it with some other random battery, not pro-rated BS. They work until they don't and then I go buy another used one. That way I am not supporting any of the retailers y'all have had bad experiences with. Plus I get to feel like I am being green with the ten cars I drive. _________________ .
Wanted:
EverettB  Administrator
Joined: April 11, 2000 Posts: 71823 Location: Phoenix 602
Posted: Tue Jan 11, 2022 10:21 pm Post subject: Re: When a warranty is not what it says |
| Rich Latsch wrote: |
| Years ago I remember that buying a battery got you a 2-part warranty. There was an initial replacement period followed by a pro-rated period. Is that still the case? |
Yes, we recently replaced the battery in our modern car and it would have been pro-rated if the complete warranty period had not expired... which is rare for AZ, batteries wear out quickly here from the heat. _________________ How to Post Photos
Zundfolge1432  Samba Member
Posted: Tue Jan 11, 2022 8:23 pm Post subject: Re: When a warranty is not what it says |
Itโs been this way for years even that old dinosaur sears did it like that. Hereโs another stunner, tires have warranty that is prorated too. I got some money back on set that didnโt go the 80k as advertised. |
Bonesberg55 Samba Member
Posted: Tue Jan 11, 2022 5:03 pm Post subject: Re: When a warranty is not what it says |
Posted: Tue Jan 11, 2022 4:56 pm Post subject: Re: When a warranty is not what it says |
| It probably would have helped if you had been wearing your pajamas when you went in there! |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13583 Location: Tejas!
Posted: Tue Jan 11, 2022 4:14 pm Post subject: Re: When a warranty is not what it says |
| Lingwendil wrote: |
| Tires, Batteries, etc anything on the car with one of those warranties I generally keep in the glove box just in case. That way if I show up at another location and need to swap it I have it ready. |
yep, keep it old school |
Erik G Samba Member
Posted: Tue Jan 11, 2022 4:13 pm Post subject: Re: When a warranty is not what it says |
First of all F-Walmart. If you shop at Walmart you are part of the problem.
Don't buy a battery at Advanced Auto. They are independently owned franchises, their computers do not talk to each other. If you are on the other side of the country and your battery fails, the advance auto you go to cannot look it up. They have to call the original store you bought the battery from to get the ok to warranty it out. Big mistake, never again. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3999 Location: Antioch, California, a block from the hood
Emily's Owner  Samba Member
Joined: January 18, 2004 Posts: 1031 Location: Canby, Oregon
Posted: Tue Jan 11, 2022 10:06 am Post subject: Re: When a warranty is not what it says |
| 2type2 wrote: |
I admit there was no receipt, but the battery was a exact replacement and had a sticker showing it was 19 months old. I use Waly batteries because I can replace them easily, anywhere. I'm at the age where I just anticipate bullshit ahead of time and weigh whether it's best to walk ,balk, or just bite the bullet. Sometimes it's not worth the aggravation.
The world isn't changing really fast, it's reality being so obviously exposed for what it really is. |
I think Les Schwab does this (depreciating value within warranty thing). I've also learned that having a receipt doesn't necessarily matter as LS goes by the date sticker on the battery itself. So if your battery sticker is already "months old" when installed, then you're outta luck when you take it back for an issue under the date on your receipt but aged out on the battery itself (our battery problems were travel trailer related). So I now check the stickers on the battery when installed. _________________ Xargaret
ITMC - OG Den Mother
What (and I cannot stress this enough) The Actual Fuck?!
1974 Transporter
2025 Subaru Outback |
Posted: Tue Jan 11, 2022 9:28 am Post subject: Re: When a warranty is not what it says |
| Much of getting the desired outcome depends on how you relate to the person behind the counter. Iโm not saying you need to be a door mat but if you come off as pleasant they might be more inclined to work with you. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33394 Location: Hot Arizona
Posted: Tue Jan 11, 2022 6:44 am Post subject: Re: When a warranty is not what it says |
About 3 months ago, I had a 34-month-old Walmart battery with a 36-month replacement warranty. My 1988 Mazda truck was having intermittent "no crank" situation, and the ignition switch tested fine, so I figured why not get a new battery. Was zero trouble/hassle, and I didn't pay a penny.
By the way: the issue turned out to be bad contact between some of the grounding spots and the negative cable (on engine and frame), just needed good sanding and cleaning. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Jan 11, 2022 5:37 am Post subject: Re: When a warranty is not what it says |
Every time Iโm tempted to go to a bid box I play โLittle Manโ and then go visit one of the people who built the community I enjoy.
Most battery warrantyโs are prorated in some form or other. Iโve never had to replace one on warranty but I use trickle chargers on all my cars in winter _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
2type2 Samba Member
Joined: June 02, 2002 Posts: 1199 Location: SW Colorado
Posted: Tue Jan 11, 2022 5:35 am Post subject: Re: When a warranty is not what it says |
The world isn't changing really fast, it's reality being so obviously exposed for what it really is. _________________ "A life of peace and happiness depends on your own gratefulness" |
iowegian  Samba Curmudgeon
Joined: February 16, 2005 Posts: 9977 Location: Somewhere between Dubuque and Keokuk
Posted: Tue Jan 11, 2022 4:42 am Post subject: Re: When a warranty is not what it says |
| Iowa Mark wrote: |
I can't bad mouth Walmart at all. Last year I ordered a pair of tires online. A couple of days later I got an e-mail, my tire was in at the store. I went down and customer service said it was back in drive up pick-up. The other one was shipped from another location. I walked back to the back of the store for the tire and the girl there said it had been taken to automotive. I go to automotive and there is one tire. On the way to the front of the store the girl from pick-up catches me with the other tire. I sign both copies of received paperwork and head out. The next day I get an e-mail telling me my other tire is at the store. I call and tell them the story from the day before and we both laugh at how screwed up online sales are in these crazy days. Three days later I get a message that Walmart is refunding me for the lost tire. Before I could call about all this I get a "How would you rate your shopping experience at Walmart?" There is an 800 number, so I call. Jemal and I laugh about how screwed up all this is and in the end, he tells me to forget about the whole thing. The cost of the tire is already more than made up by all the time trying to straightening this out. "Thank you for shopping at Walmart".  |
Such a heartwarming story on a cold January day.  |
finster Samba Member
Joined: May 26, 2012 Posts: 10432 Location: not far from the madding crowd
Posted: Tue Jan 11, 2022 3:25 am Post subject: Re: When a warranty is not what it says |
I would ask to see the particular piece of small print covering the replacement cost. I've never known this to happen when replacing anything under warranty. _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Iowa Mark Samba Member
Posted: Mon Jan 10, 2022 9:52 pm Post subject: Re: When a warranty is not what it says |
Cusser Samba Member
Posted: Mon Jan 10, 2022 8:55 pm Post subject: Re: When a warranty is not what it says |
| Joe 20 wrote: |
| .even though it is a Walmart battery. |
Walmart batteries are made by Johnson Controls/Clarios, who makes like 85% of the batteries in USA, including Interstate, Costco, Autozone, O'Reilly.... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
