storm Samba Member
Joined: April 28, 2008 Posts: 323 Location: Juneau, Wisconsin
Posted: Thu Jan 20, 2022 9:07 am Post subject: Re: Front brake hi frequency noise…FOUND! |
I once had a similar noise when leaving a car show. Some of the people there I knew. I found out later that the high pitched noise coming from the front of my ‘71 camper with front disc brakes. I pulled over to look underneath and saw a styrofoam cup wedge near the rotor. A guess it was a joke. My passengers were laughing. Ha ha. I did get even with them, that’s another story. _________________ always ready to learn and give advice |
Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 1081 Location: Seattle, Wa
Posted: Mon Jan 17, 2022 10:42 am Post subject: Re: Front brake hi frequency noise…FOUND! |
My old drums were too far out of tolerance, otherwise I would have turned them. Looks like I will have to shave some material off the inner hub for more clearance. Hopefully easy.
Bill |
sled Samba Member
Posted: Mon Jan 17, 2022 9:07 am Post subject: Re: Front brake hi frequency noise…FOUND! |
why did you get new drums? could the original drums not be turned? _________________ drive your split. |
Posted: Sun Jan 16, 2022 6:50 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
I believe I have found the problem. I dug out my original drum and compared the inner hub with the new one. Looks like the original has a longer cut on the hub which creates more space for the springs. Glad I hold on to my old parts. The original is in the 1st photo, the new one 2nd photo.
Bill
Posted: Sun Jan 16, 2022 4:14 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
I went ahead and bent the straight part on the springs and flipped them. Test drive was a success so the frequency noise is gone. What I don’t like is now the springs actually rub against the wheel cylinder housing. That can’t be proper. Still gotta come up with something better. Anybody actually have the proper springs?
Bill |
Starbucket Samba Member
Posted: Sun Jan 16, 2022 4:13 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
[quote="Pepperbilly"]
Starbucket wrote: |
Why not drill a hole for the spring that gives you the clearance you need?[/quote
Do you mean in the brake shoe backing plate?
Bill
No, in the shoe to lower the spring so it doesn't rub. |
Posted: Sun Jan 16, 2022 4:06 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
[quote="Starbucket"]Why not drill a hole for the spring that gives you the clearance you need?[/quote
Bill |
Posted: Sun Jan 16, 2022 3:26 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
Why not drill a hole for the spring that gives you the clearance you need? |
Posted: Sun Jan 16, 2022 2:40 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
Since mine is a ‘67, is that considered early? I see the springs posted with the curve but are they for a much earlier bus? The front brakes are different on a ‘67 and I can’t remember if it was a one year only deal. Unfotunately, I no longer have my originals. Guess I will probably have to find some originals.
Bill |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2359 Location: Millwood, Wa
Posted: Sun Jan 16, 2022 1:55 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
Original early springs:
Installed correctly:
I would find original parts, can not imagine new springs are worth anything, like most new parts. _________________ ---
Trying to keep poor cool
People are talking, the greatness is coming, going to be greater than great, so great, greater than anything ever.
Clara  Samba Member
Posted: Sun Jan 16, 2022 1:00 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
Yours is the top pic, the middle from the gallery, the lower one I posted of 3/4 ton front brakes.
I think the springs you are using are made differently. I would spin them around, or replace them.
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4019 Location: San Diego
Posted: Sun Jan 16, 2022 11:57 am Post subject: Re: Front brake hi frequency noise…FOUND! |
Springs should not rub on hub or wheel cylinder. Aftermarket springs are made wrong. Look at what position the coil is where it transitions to the long section. Bending the springs works, but probably not the best way. Sometimes flipping the springs works also |
Posted: Sun Jan 16, 2022 11:34 am Post subject: Re: Front brake hi frequency noise…FOUND! |
I think first I will try to make adjustments on the spring itself. If not successful with that I may think about removing some metal off the inner hub where the spring rubs. It does not have to be mucn. You can clearly see in the photo the dark ring where the rubbing was happening. Has anyone ever tried turning down this area on a lathe?
Bill
livnlow Samba Member
Joined: May 03, 2005 Posts: 57 Location: Jacksonville, Florida
Posted: Sat Jan 15, 2022 8:26 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
ive had this happen in the past and I bent a small amount of curve into the center straight section of the return spring. it solved the problem for me _________________ 1963 356B Coupe
1965 sundial |
Posted: Sat Jan 15, 2022 8:11 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
Yeah, all new stuff and you may be on to something. I dug up some old photos of original springs. I think my new ones are wound incorrectly for a bus or they are the wrong ones. Looks like the originals have the long straight section exiting the coil on the same plane as the hooks. May have to look at other springs.
Bill |
69aircooled Samba Member
Joined: August 04, 2004 Posts: 254 Location: North Carolina
Posted: Sat Jan 15, 2022 6:57 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
Looks like all new components, that’s good, but sometimes bad in that the parts are not always made to exact original specifications. Either the hub of your drum is too big in diameter or possibly the springs don’t have the correct bends. If you have the old springs maybe compare them, possibly reuse them. As you mention, you could try moving the springs so the straight section is further out, contacting the WC base. Maybe some others will chime in having had this similar situation and provide advice. |
Posted: Sat Jan 15, 2022 6:34 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
I could try turning the springs around but it seems that would be a pretty big bend to go around the WC. I don't ever remember the spring coming into contact with the WC. I would have to do this to both top and bottom springs because they are both contacting the hub.
Bill |
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1367 Location: Bay Area, California
Posted: Sat Jan 15, 2022 5:49 pm Post subject: Re: Front brake hi frequency noise…FOUND! |
Before I added my front disc brake kit in 2015, I redid my front drum brakes:
The shoe springs I was using, forced the long wire into the wheel cylinder, it's pushing hard on its own, you can see the coils straining against it. Perhaps your shoe springs have a particular bend to them, that makes them directional, or top and bottom.
I would try turning your lower spring around, so that the long wire presses against the WC.
_________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Sat Jan 15, 2022 5:34 pm Post subject: Front brake hi frequency noise…FOUND! |
But what to do now and why is this happening? The noise was from the front wheels when moving…very hi frequency but resonated thru the bus while driving. Well, I found that the brake shoe springs were in contact with the drum hub while turning. Photos show where the contact was occurring on the springs. You can also see in the last photo where there is a blackish ring worn into the center hub where the spring was contacting…but just barely. I am not sure what the proper fix is at this point. Any help is greatly appreciated. 1967 Westy. Stock.
Bill
