Eberspacher heater and Okrasa dual carbs - does it fit?
Clara Premium Member
Clara is offline
PostPosted: Thu Jan 20, 2022 4:43 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
There is not much room between the 1600 engine and the Eberspacher in this 56 bus. It makes it a bit awkward to change the plugs on the left side. 2008 pics.
The heat is really nice.
earlywesty
earlywesty is offline
PostPosted: Thu Jan 20, 2022 4:36 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
Braukuche wrote:
mandraks wrote:
Braukuche wrote:
Hey Eric, I spaced, it’s a Bristol. John at air cooled has them. If you go the Judson route I’ve been hoarding a 36hp ambulance intake with the shorter neck for years. I’m thinking it is short enough that you don’t have to cut a hole in the luggage tray to clearance the air cleaner on the carb.
https://vwparts.aircooled.net/30-PICT-1-Stock-Carburetor-Manual-Choke-113129027-p/113-129-027br.htm
Bocars, Bristol, Brosol, what's the difference when you are among friends Smile
I got spell CHECKED!
Don't worry about it, I got ya. Thanks man
Braukuche
Braukuche is offline
PostPosted: Thu Jan 20, 2022 3:07 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
mandraks
mandraks is offline
PostPosted: Thu Jan 20, 2022 1:10 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
regards
Uli
Braukuche
PostPosted: Thu Jan 20, 2022 8:29 am    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
buseric wrote:
Braukuche wrote:
Whoops forgot your running a 36hp.
Sett8ng aside dual carbs you could build a stroker with a big bore, 69.5 crank and 80mm pistons which are off the shelf, or a Porsche A/B 74mm crank machined for VW rods and use AAs shortened rods. For carburation you could use one of those 30 PICT Bocars with the manual choke or if money is no object get ahold of a Judson supercharger and an ambulance intake with the shortened neck.
This might be exactly what i do. Dual carbs really wake a motor up in my experience but this might be a good middle ground. Thanks for the thoughts Dan. I have heard mixed reviews on the Bocar carbs, but that was more on the 34pict copy. That said, I have used one successfully. Any hints on where to find the manual choke version of the 30 pict?
Hey Eric, I spaced, it’s a Brosol. John at air cooled has them. If you go the Judson route I’ve been hoarding a 36hp ambulance intake with the shorter neck for years. I’m thinking it is short enough that you don’t have to cut a hole in the luggage tray to clearance the air cleaner on the carb.
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia
earlywesty
PostPosted: Thu Jan 20, 2022 5:17 am    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
Braukuche
PostPosted: Wed Jan 19, 2022 7:46 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia
earlywesty
PostPosted: Wed Jan 19, 2022 7:37 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
busdaddy wrote:
Has anyone tried a 72-74 bus firewall duct?, it tilts the heater to clear dual carbs, but if things are sticking out of the heater that interfere with other shit a custom exhaust pipe would be the least of your issues.
Id have to find a pic to see what you mean Mark. Be nice to explore all options.
busdaddy
busdaddy is offline
PostPosted: Wed Jan 19, 2022 6:54 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
Слава Україні!
earlywesty
PostPosted: Wed Jan 19, 2022 5:18 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
crofty wrote:
buseric wrote:
crofty wrote:
A bit more involved than that.
Below the heater is the rail the bumper brackets are attached too. you'd also have to cut a verticle support and the heater might not fit that close to the wheel well because of its length.
The flame switch on the 8478 heater is on the side and that might present a problem too.
ToolBox wrote:
buseric wrote:
perello wrote:
I can answer because I tried.
It does not fit.
It would need tweaking both the support bar at the bus and the heater itself (too close to carb).
I guess that explains why I can't find pics of the combination. Darn.
You could always move the heater over and install a custom duct.
This. Its fairly involved and the bus is significant so won't be getting hacked. I wondered if I could relocate the flame switch and that would make the difference? This makes the 8478 a tighter fit than later heaters.
If your Bus came with its heater, its NOS and i wouldnt alter that heater either!
Well, it does look NOS, I was unsure if restored or NOS. I have 2 and both are nice....hmmm... go fast or heat....decisions
crofty
Judas of the North
crofty is offline
PostPosted: Wed Jan 19, 2022 3:34 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
ToolBox wrote:
buseric wrote:
It does not fit.
HamburgerBrad wrote:
earlywesty
PostPosted: Wed Jan 19, 2022 3:05 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
ToolBox wrote:
buseric wrote:
It does not fit.
tisius
tisius is offline
PostPosted: Wed Jan 19, 2022 1:22 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
this is interesting Exclamation
drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
Braukuche
PostPosted: Wed Jan 19, 2022 9:33 am    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
You have to pick heat or speed. Or just do what I did and use a modified 34PICT on a 1800. Bus does 70 easily.
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia
crofty
Judas of the North
crofty is offline
PostPosted: Wed Jan 19, 2022 9:16 am    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
ToolBox wrote:
buseric wrote:
It does not fit.
ToolBox
ToolBox is offline
PostPosted: Wed Jan 19, 2022 9:03 am    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
buseric wrote:
It does not fit.
earlywesty
PostPosted: Tue Jan 18, 2022 1:04 pm    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
It does not fit.
perello
perello is offline
PostPosted: Tue Jan 18, 2022 8:02 am    Post subject: Re: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
It does not fit.
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
earlywesty
PostPosted: Tue Jan 18, 2022 6:08 am    Post subject: Eberspacher heater and Okrasa dual carbs - does it fit? Reply with quote
Hi all,
I have searched here and the gallery but haven't been lucky in finding what I need to know. Has anybody tried the specific combination of an Okrasa 36hp motor with an early Eberspacher installed in the stock location? I am talking about the 8478 Eberspacher model, not a BN4 and the Wolfsburg West kit for 36hp. In looking at pics of both installed separately it looks like it would be awful close....particularly as the early heaters have a relay or something that is mounted on the side and sticks out towards the motor.
This is the heater I am referring to
And a pic of the motor (thanks Todd)
