Alternator/generator light proper voltage measurement 66 bug 12v
HENDO
HENDO is offline
PostPosted: Wed May 07, 2025 4:02 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
ashman40 wrote:
HENDO wrote:
Ok that makes sense. It just had me stumped because the voltages coming out of the alternator and at the battery terminals are normal except what is coming out of that D+ terminal, which only runs to that light from what I can tell, unless.it is wired incorrectly.
From my reading of VW alternators, the D+ and B+ are similar and the output voltage on each should be the same. The only diff is that B+ can support more amperage to power the electrical systems and recharge the battery. The D+ only need power the VR and the GEN lamp. But you say the D+ voltage is up above 17v while the B+ and battery are closer to normal (14v). This suggests the internals of the alternator have gone bad. Time for a rebuild.
Yep that's what is happening. I'm gonna pull it and start shopping for a new one.
Thanks for the input.
84 Westy AKA "Sludge"
ashman40
ashman40 is offline
PostPosted: Wed May 07, 2025 3:49 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
AshMan40
HENDO
HENDO is offline
PostPosted: Wed May 07, 2025 2:55 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
Ill just pull the alternator out of my 66 and use it. I have that all torn apart to restore anyway.
HENDO
HENDO is offline
PostPosted: Wed May 07, 2025 2:54 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
scrivyscriv wrote:
The light comes on based on differential voltage, or differential potential.. it doesn’t care which side is ground or not. It just needs the voltage one on leg to be higher than the other, and it will light up.
When your alternator fails and is overcharging, it will light up.
When your alternator fails and doesn’t charge, it will light up. Current is flowing different ways in those examples but it doesn’t matter.
So yes if you’re revving up and the light gets brighter, your alternator is overcharging, usually a diode is shorted in that case.
17 volts is not okay. It will make the battery explode if you drive too long like that
It’s repairable. Most would recommend taking it to a starter repair shop versus buying a Chinese aftermarket new pRt
Ok that makes sense. It just had me stumped because the voltages coming out of the alternator and at the battery terminals are normal except what is coming out of that D+ terminal, which only runs to that light from what I can tell, unless.it is wired incorrectly. This is a fairly new to me bug.
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Wed May 07, 2025 2:28 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
Robert in Memphis
Engine rebuild thread
HENDO
HENDO is offline
PostPosted: Wed May 07, 2025 1:52 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
herbie1200 wrote:
Do not waste time with all those measurements.
The light check is very simple.
Turn ignition on, engine stopped. Then:
1) The gen light should go on.
2) go to the alternator, disconnect the D+ wire, the gen light should go off.
3) Finally short the wire to ground, the gen light should go on.
If these 3 point are OK, the gen light and its wiring are OK.
Please report and we go forward in the analisys.
I just did this on my 63 with an alternator and it checks out fine in that test.
My issue is last week while out driving I noticed the red light on...the higher rims, the brighter it gets. It is charging fine putting out around 14 volts read off the alternator and the battery. Reading the voltage off the D+ terminal I get like 17.4 volts. I swapped out that square piece with the D+ terminal with the one on my 66's alternator and got the same result.
Anyone encounter this issue??? It is charging fine. The only issue is that red light now...I am hoping anyway.
herbie1200
herbie1200 is offline
PostPosted: Tue Apr 05, 2022 1:23 am    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Thu Mar 31, 2022 6:24 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
I skipped down to the reply box the instant I heard the equivalent to: "glowing charging lamp" without reading the other replies yet. I just wanted to interject VW's own statement on this phenomena in the Generator Era:
I lived with this for years on my 62 Beetle, not knowing which link in the chain was the culprit until it came to a head. I was driving in I-70 in the mountains of Colorado, where I lived at the time. Fortunately this did not happen in the very long Eisenhower Tunnel, but one of the other shorter tunnels, the charging lamp started to glow really bright and then... nothing. The ignition switch gave out. That was the culprit. I was able to coast to a stop on the shoulder outside the tunnel and hot-wire the car. Later, I dismantled another compatible ignition switch (not exactly easy as I don't think they were assembled with the intent to ever take them apart again, kind of like the mechanical fuel gauges of the era) and marry my tumbler section to that switch, so I fixed it retaining my keyway.
Andy T.
ashman40
ashman40 is offline
PostPosted: Tue Mar 29, 2022 8:25 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
When doing ANY electrical work... disconnect the negative terminal from the battery.
Testing is a slightly different story.
AshMan40
mikesbeetle
mikesbeetle is offline
PostPosted: Tue Mar 29, 2022 1:15 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
I appreciate the input. Is there any risk to taking off that component on the alternator and inspecting it with the battery still hooked up or should I completely disconnect the battery first?
toxicavenger70
toxicavenger70 is offline
PostPosted: Tue Mar 29, 2022 6:58 am    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
If it was me I would check all the wiring to see if all the connections are cleaned and wired correctly.
Here is a thread showing were the internal regulator is located. https://www.thesamba.com/vw/forum/viewtopic.php?p=8836146
If there is a short on the D terminal like Ashman said you can remove the black box on top (holds the brushes) and see if there are any issues with the connections on the back of it.
ashman40
ashman40 is offline
PostPosted: Mon Mar 28, 2022 9:21 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
From those readings, it sounds like there is a short to ground inside the alternator D+ terminal.
Time to remove you alternator and take it to your FLAPS or local automotive electrical shop to test it. If it is bad, then you should be looking for a replacement new or rebuilt. Just be sure to test the replacement before you go thru the effort of reinstalling it. I would hate for you to find you got a dud and have to go thru the effort of removing it and reinstalling a replacement all over again.
AshMan40
mikesbeetle
PostPosted: Mon Mar 28, 2022 6:36 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
Thanks for the guidance everyone!
It looks like based on the results the alternator is bad but here are my results:
Notes:
I had the battery on a trickle charger like usual and it was at full charge before starting my testing. Charger was disconnected before any testing started.
The GEN and OIL light both come on when I turn the key on.
As I sit in the driver seat, the OIL light on the right goes out when I turn the engine on. GEN light on the left stays on, even with higher RPM.
I’m not sure where the 2 wires go from B+. They both go behind the firewall, my guess is the right one goes to the battery and the left to the front of the car. There is no junction under my rear seat like you said is on some cars.
Readings on wires that went in to the speedometer are in the image below for reference to make sure I’m using the correct reference for the wires.
The GEN light wire whether the engine was on or not read about 1.9v
The bottom terminal to the speedometer (black cable) read about 11.3v - ignition on and/or engine on. It was interesting to me the blue/green cable on the left only read voltage with the engine on.
Suggested tests performed:
Disconnect D+ from alternator and test loose wire: 10.65v
Test D+ terminal with wire disconnected: -.82v
-Reconnected cable-
Test voltage at B+ terminal (ignition on/engine off): 11.48v
Test voltage at D+ terminal (ignition on/engine off): .5v
-Start Engine- (GEN light on/OIL off)
Test voltage at B+ terminal (engine on): 11.6v
Test voltage at D+ terminal (engine on): 1.26v
-Rev Engine to 2100 rpm and hold- (GEN light on/OIL off)
Test voltage at B+ terminal (engine on): 11.8v
Test voltage at D+ terminal (engine on): 1.2v
Battery reading - Engine on:
12.18v at Idle across the posts
Reference photo.
Cusser
Cusser is offline
PostPosted: Mon Mar 28, 2022 7:18 am    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
Test voltage across the battery terminals with engine running. Should read about 13.5 to 14.5 volts.
Do NOT disconnect the battery while engine is running !! Can damage any alternator.
ashman40
ashman40 is offline
PostPosted: Sun Mar 27, 2022 11:17 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
mikemunoz wrote:
The bug was a 12v conversion when I got it and uses an alternator with I believe an internal voltage regulator since I can’t locate one... Wiring diagrams I find seem to point to a voltage regulator.
VW used an external VR up thru the '74 model year so expect to see a VR in the wiring diagrams. After '74 they went to an internally regulated alternator.
That is an AL-82 alternator with an internal VR. It has a simple 2-wire hook up. The B+ terminal is the main output and powers the electrical system and recharges the battery. Normally, there is a single heavy gauge wire coming off the B+ stud which heads to a junction below the rear seat. ON dune buggies the wire often runs to the battery cable stud on the starter solenoid. Functionally it works the same. Not sure why yours has two wires coming off B+? Where do these two wires run?
mikemunoz wrote:
I measured voltage on the cable to this light on the speedometer and only get 1.5 volts or so. Everything else to the speedometer seems a little under 12... I'm assuming I should be seeing near 12 on that cable? Where does the other end connect to?
Did you test for voltage while the wire was still connected to the GEN lamp? You tested the GEN lamp and not the OIL lamp, right?
With the ignition switch in the ON/RUN position and the engine not running, the three (3) indicator lamps at the bottom of the speedometer are powered by the single black wire running to the bottom terminal of the speedometer. This wire is powered from the fuse box. Test this wire for 12v.
Each of the blue wires coming off the 3 bulb holders runs to a switch ground which turns the lamp ON. With the engine not running, the OIL lamp and the GEN lamp should both be ON as the other end of the wires will be grounded.
Test:
Before you start the engine, turn the key to the ON/RUN position. This should apply power (12v) to the three indicator lamps at the bottom of the speedometer. The OIL and GEN lamps should turn ON as each of these wires should be grounded before the engine starts. The OIL lamp is grounded at the oil pressure switch below the distributor. The GEN lamp should be grounded thru the alternator D+ terminal.
The GEN lamp turning ON here before the engine starts is a prerequisite for the charging system to work. Voltage from the speedometer GEN lamp passes thru the field coil in the alternator and creates a small magnetic field which gets the alternator charging. If the bulb is burnt out, the fuse is blown or the wire to D+ is disconnected, the alternator will never start charging because the magnetic field is missing.
Disconnect the D+ wire at the alternator and test the loose wire for 12v coming from the GEN lamp. Ground the wire and you should see the GEN lamp turn ON.
Test the D+ terminal on the alternator with the wire disconnected. There may be a very small voltage (<1.0v). Anything higher and your alternator may have internally failed.
Reconnect everything normally. WIth the ignition ON, confirm with GEN lamp turns ON before you start the engine.
Test the voltage at the B+ and D+ terminals with the ignition ON and engine not running. You should see battery voltage at the B+ terminal and something slightly less at the D+ terminal.
Start the engine. The GEN and OIL lamps should turn OFF almost immediately.
Test the voltage at the B+ and D+ terminals at idle. They should be nearly the same voltage on both as the alternator is now outputting a charge voltage on both. It may be battery voltage or slightly higher. A good working alternator can produce 13.8v (charging voltage) at idle.
Rev the engine to around 2100rpm and hold it there. Test the voltage at the B+ and D+ terminals. You should now see a charging voltage of 13.8v+. You don't want to see more than 15.0v.
If the GEN lamp is turning ON before you start the engine and the alternator is unable to output 13.8v+ on the B+ while you rev the engine... you alternator fails the test.
If the GEN light remains ON even when the ignition switch is turned OFF, your alternator has internally failed and needs to be replaced/rebuilt.
Report back your finding.
AshMan40
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sun Mar 27, 2022 8:26 pm    Post subject: Re: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
Normal battery voltage is 12.66 volts direct current of vdc.
Alternator should put out between 12.8 to 14.6 vdc. Really depends on several variables, but I like to see 13.1 - 14.2vdc. If it will maintain this through a load test, then all is good.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
mikesbeetle
PostPosted: Sun Mar 27, 2022 8:13 pm    Post subject: Alternator/generator light proper voltage measurement 66 bug 12v Reply with quote
Hello:
I’ve researched numerous posts on the topic since it seems popular but can’t find my answer. I have a 66 bug for about 10 years now. Recently I noticed a very dim alternator light when driving around. No big deal, battery seemed ok. Just recently, during a drive the light came on and now stays fully lit (when car is on). Fan belt is fine. I measured voltage on the cable to this light on the speedometer and only get 1.5 volts or so. Everything else to the speedometer seems a little under 12.
The bug was a 12v conversion when I got it and uses an alternator with I believe an internal voltage regulator since I can’t locate one. Including a picture for reference. I'm assuming I should be seeing near 12 on that cable? Where does the other end connect to? Wiring diagrams I find seem to point to a voltage regulator.
Thanks for any help.
