jlrftype7 Samba Member
Posted: Tue Apr 26, 2022 1:57 pm Post subject: Re: E-brake issues and what else can I check when I'm in there? |
I will add this, reference the picture of the correctly assembled Rear Brakes here on Samba that our Mod Dave has posted from time to time. There are some TRICKY issues that happen if left is on the right, or one of the adjusting parts for the shoes is upside down, that sort of thing. Some of the differences are subtle, hard to spot if your brakes were assembled wrong to begin with and you're following the previous person's foot steps inside the drum.....
Maybe Dave can find and post that great picture. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5864 Location: Bemidji, MN
Posted: Tue Apr 26, 2022 6:27 am Post subject: Re: E-brake issues and what else can I check when I'm in there? |
think about replacing the shifter ball the shift rod rides thru. inspect your coolant lines and if the ones to the heater are puffy, replace them. now would also be a good time to consider a new battery cable. the ends get corroded and the copper strands break, reducing conductive surface area. not enough spare length to just tug and put new ends on. i believe the cable size was bumped up after 85 too. more diameter is always better.
be prepared for the deep dive on the rear brakes and my advice would be to have EVERYTHING on hand... spring kit, shoes, new cylinders with the spring in the middle, e brake cables, flex hoses but then the union at the steel line to flex hose will be all rusted so you'll have to cut back into fresh steel line, put a union in and bring new steel/NiCopp line up to the flex hose. it's all 40 year old stuff bathed in corrosives. if you can re-use your old drums after having the wear ridge turned down, they won't be warped like all the new Chinese ones will be.
it's all worth it... a working parking brake on these vans is a joy to behold but you'll have die in battle before you get to Valhalla. _________________ -dan
www.thefixitworkshop.com |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8476 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Apr 26, 2022 4:12 am Post subject: Re: E-brake issues and what else can I check when I'm in there? |
Busted. Shoulda gone to bed early, instead of scooting the interwebs...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7284 Location: Honolulu,Hawaii and France
Posted: Mon Apr 25, 2022 7:17 pm Post subject: Re: E-brake issues and what else can I check when Im in there. |
dhaavers wrote: |
Quote: |
Check and reseal fuel tank? Maybe a new sending unit? |
Yes and yes. It's only money...
Dave will tell you to freshen the fuel pump ground (hidden above the tank) and I agree with him, too.
- Dave |
Did you mean the fuel sender ground?  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Mon Apr 25, 2022 6:50 pm Post subject: Re: E-brake issues and what else can I check when Im in there. |
"The WonderVan"
Dormungus Samba Member
Joined: July 24, 2016 Posts: 35 Location: Bremerton, WA
Posted: Mon Apr 25, 2022 12:07 pm Post subject: E-brake issues and what else can I check when I'm in there? |
Hi again,
When I started on my 85 GL, I found metal parts under seats and in the glove box. One Ive recently I identified is the parking brake equalizer which was in the glove box. For some reason the center ebrake cable is not there. Im going to replace all three cables. Im renewing the CV's, brakes, and wheel bearings at the same time.
Since I read that I probably need to drop the tank to work on the center ebrake cable, What else can I do up there? Check and reseal fuel tank? Maybe a new sending unit?
While I have the tank out, is there anything that would be nice to chevk/renew so that area can stay buttoned up for a few years? |
