dustymojave Samba Member
Joined: January 07, 2007 Posts: 5820 Location: Lake LA, Mojave Desert, SoCal
Posted: Sun May 29, 2022 9:19 am Post subject: Re: Front end lift on Baja bug advice needed… |
Yes. It would be fine to cut and re-weld without adjusters or with adjusters.
I have a beam out back from a Hi Jumper buggy that belonged to my friend many decades ago. The car had started out as a play buggy with no body panels and an almost stock suspension. Then he decided to go offroad racing with it. So I rebuilt the car for him.
The original link pin beam had been built in about 1975 by somebody else with a cut & turn in the middle. When they took it out the 1st time, it was rock hard. Turned too far. Then it was cut again and turned back a bit so it was appropriate for the buggy mild desert and still some dune play use they intended for the car then. When we prepped it for racing, he wanted adjustable torsions. So we started with another stock beam, cut it, installed adjusters and taller shock towers. But the original beam for the buggy would still be fine to be used on a Baja or buggy.
You could do the same for yours. Cut it again near, but not at the original cuts. _________________ Richard
SoCalBajas Member
Akimbeau Samba Member
Joined: May 09, 2022 Posts: 22 Location: Baja California
Posted: Fri May 27, 2022 2:08 am Post subject: Re: Front end lift on Baja bug advice needed… |
Thanks, for the in-depth explanation! Points all well taken. Do you think I could just cut the beams again and weld in the adjustable center mounts? I can find a way to get the adjustable mounts down here but a front beam might be hard to come by. |
Posted: Sat May 21, 2022 9:11 pm Post subject: Re: Front end lift on Baja bug advice needed… |
I agree with Dennis here.
Removing one set of leaves and replacing them with a through rod would not be a good thing to do.
The stock leaves, upper and lower together, are just fine for spring rate for the front of a mild Baja Bug. Apparently what happened here is that the beam was cut and rotated too far for a mild Bug. Some people think if its good for a racer, then it must be right for their mostly street Baja Bug. But that's not right. _________________ Richard
SoCalBajas Member
DHale_510 Samba Member
Joined: August 27, 2010 Posts: 407 Location: Nampa Idaho
Posted: Sat May 21, 2022 7:43 am Post subject: Re: Front end lift on Baja bug advice needed… |
Akimbeau wrote: |
Dark Earth wrote: |
Just out of curiosity Dusty, what would happen, if say, the OP removed the torsion leaves out of the top tube, and ran just one through bar leaving the lower torsion leaves intact ?? Would that then be too soft to drive ?? Would that cause damage from bottoming out ?? |
That’s an interesting option….🤔 |
You are confusing spring rate and preload.
The spring rate is the measure of pounds of load per distance of suspension travel. The weight of the car determines what this should be. For stock stuff that is about 75#/" over about 8". Jumping and going fast may need more. Remember that you want about half travel down and half up. What you have now is all up and no down and that is your roughness problem, not the spring rate. Removing half of your springs will simply make everything so soft you will be constantly "bottoming" and breaking things that do not spring back.
Preload is where you set the springs before you put weight on them. This does not change the spring rate, but alters the up travel to down travel ratio. Twisting the center mount changes the preload. You currently have too much preload for your use which eliminates the down travel and feels too stiff. It is not really too stiff, but it is harsh from no down travel. This will break things not intended to flex, including passengers.
Shock absorbers change the rate the springs react, they do not change the spring rate. Higher rate springs need higher rate shocks. Sometimes you can fit shocks made for heavier cars and change the rate, but usually you will need special limited production and more expensive ones. That's why they exist. Too soft shocks are usually going backwards.
Replacing the beam is the easiest and cheapest option.
Dennis |
71StandardReduction Samba Member
Joined: December 04, 2012 Posts: 785 Location: Louisiana
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2279 Location: No. Idaho
Posted: Fri May 20, 2022 8:54 am Post subject: Re: Front end lift on Baja bug advice needed… |
How would one go about mounting a coilover in that location and avoid interference with the control arm? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Posted: Wed May 18, 2022 3:49 pm Post subject: Re: Front end lift on Baja bug advice needed… |
Dark Earth wrote: |
Posted: Wed May 18, 2022 1:53 pm Post subject: Re: Front end lift on Baja bug advice needed… |
And I believe your assessment is correct, Dusty, that it was turned a bit too much. Thanks for the in-depth explanation.
Kim |
Posted: Wed May 18, 2022 1:47 pm Post subject: Re: Front end lift on Baja bug advice needed… |
I had no idea coil overs for that application would be so expensive. I’ve purchased double adjustable coil-over shocks with springs for 2 of my road racing cars for less than $600 a pair. But I wouldn’t need all that adjustability either so I figured it would be even cheaper. The hard part would be figuring out the proper length and spring rate of the springs. |
Dark Earth Samba Member
Posted: Wed May 18, 2022 8:49 am Post subject: Re: Front end lift on Baja bug advice needed… |
Just out of curiosity Dusty, what would happen, if say, the OP removed the torsion leaves out of the top tube, and ran just one through bar leaving the lower torsion leaves intact ?? Would that then be too soft to drive ?? Would that cause damage from bottoming out ?? _________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
Posted: Tue May 17, 2022 6:05 pm Post subject: Re: Front end lift on Baja bug advice needed… |
Akimbeau wrote: |
earthquake wrote: |
Your best bet would be to try to find a beam that has not been modified and replace the one you have, I don't remember who make lift spindles but there available and they won't affect ride quality. you can re-index the rear torsion a degree or two and it shouldn't lower it to much but with lift spindles in the front it ride nose high.
eQ |
I’d rather not go to the trouble of replacing the front beams. On further research on this site, I saw where through rods were used on the front trailing arms and then adjustable coil over shocks added. Then I could choose the spring rate that works and still put a lift on it. Has anyone had experience with this? Is this a good quality ride option? Do adjustable coil overs come in the stud type top mount my car will need? I know the front ball joints on my car will not be ideal for hard Offroad but that’s not what I’ll be doing with it. |
If you'd rather not replace the beam, but would rather replace your shocks with coilovers, then you haven' looked at the cost of coilover shocks. IF you find some Fox or similar coilover to fit (Fox, King and Bilstein ALL make shocks to bolt on to he front of your Bug, but not coilovers for that application), They will cost in the neighborhood of a couple of thousand US dollars. And I'm NOT talking about poor quality EMPI coilover shocks. Those a very poor shocks with a spring that only make a stock suspension ride way too stiff but are not enough to hold the car up.
If the car is too stiff now, And there is nothing wrong with it like seized arms, then the cut and turn may have been turned too far.
If you turn the torsion leaves enough for Class 11 off road racing, then it will ride terrible at low speed. If the beam is turned just enough to provide a taller ride height, that would give you stock ride quality with more clearance.
With a ball joint beam, the maximum wheel travel is around 6.5". A car with longer wheel travel can ride much softer and be no more likely to bottom out. My Baja Bug has 10.25" of wheel travel with its original arms and beam and custom fabricated shock mounts. That extra travel is one reason why link pin VW beams are so much more popular with offroaders than ball joint. _________________ Richard
SoCalBajas Member
Posted: Tue May 17, 2022 12:18 pm Post subject: Re: Front end lift on Baja bug advice needed… |
Mikedrevguy wrote: |
Can you post a pic of the shocks as it’s sits? |
Here’s some pics of the front as it sits now. I installed all new high clearance ball joints.
Posted: Tue May 17, 2022 12:12 pm Post subject: Re: Front end lift on Baja bug advice needed… |
earthquake wrote: |
eQ |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2923 Location: San Antonio, Nuevo Mexico
Posted: Fri May 13, 2022 8:30 pm Post subject: Re: Front end lift on Baja bug advice needed… |
My hardly humble opinion: the lift spindles worth having are Thing spindles. about 2 5/8" lift, large ball joints pointed down, speedo cable hole
if you exceed 6" of lift, which includes 3" chassis and 3" body lift, go wider to match the height increase. _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
Posted: Fri May 13, 2022 5:36 pm Post subject: Re: Front end lift on Baja bug advice needed… |
Can you post a pic of the shocks as it’s sits? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
earthquake Samba Member
Joined: January 10, 2008 Posts: 3993 Location: SANDY VALLEY, NEVADA
Posted: Tue May 10, 2022 2:40 pm Post subject: Re: Front end lift on Baja bug advice needed… |
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Mickey bitsko Samba Member
Joined: June 13, 2019 Posts: 511 Location: New Mexifornia
Posted: Tue May 10, 2022 12:39 pm Post subject: Re: Front end lift on Baja bug advice needed… |
Is it possible to remove torsion leaves until you get the desired ride comfort? |
Posted: Tue May 10, 2022 6:37 am Post subject: Re: Front end lift on Baja bug advice needed… |
earthquake wrote: |
The previous owner probably did a "Cut and Turn" on the front beam, look at the middle of the beam where the grub screws are and see if there is a weld on both sides of the grub screws. the rear was probably re-indexed to lift it some, does it clunk when you drive over bumps check and see if it has hook stops installed on the front trailing arms.
I only have the hook for down travel so it does not "Top Out" the shock,
eQ |
You are correct! There are welds on either side of the grub screws. So what I’d like to do is to reduce the spring rate on the torsion straps. What’s the best procedure to do this? Can I get away with cutting one of the straps on either the top or bottom torsion springs? And then if the spring rate is still too high cut the other one? Do I leave the cut strap in the torsion stack? I’m looking for a more comfortable ride, my girlfriend will be driving and riding in this car and she has back and neck issues . And again there won’t be any high-speed off-road driving.
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3252 Location: Left of everywhere
Posted: Mon May 09, 2022 9:30 pm Post subject: Re: Front end lift on Baja bug advice needed… |
Welcome
How are the shocks?
That bug doesn’t look raised 3 “ |
Posted: Mon May 09, 2022 10:58 am Post subject: Re: Front end lift on Baja bug advice needed… |
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
