Murt Samba Member
Joined: October 01, 2017 Posts: 535 Location: Kent, England
Posted: Wed Nov 09, 2022 10:23 am Post subject: Re: Easiest way to get to Speedo wiring |
HaHaHa 😂
Thank you 🙏 _________________ 1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi |
dgsaz Samba Member
Joined: November 04, 2008 Posts: 584 Location: Phoenix / San Diego
Posted: Wed Nov 09, 2022 10:18 am Post subject: Re: Easiest way to get to Speedo wiring |
If you have a lot of work under there and plan to stay for a while there's this approach:
dgsaz
crofty Judas of the North
Joined: August 09, 2000 Posts: 19818 Location: Land of Whine and Phonies
Posted: Tue Nov 08, 2022 11:17 am Post subject: Re: Easiest way to get to Speedo wiring |
mastorna wrote: |
You likely can do the Speedo with the dash tray installed but it’s 3 screws and you’ll be so much happier fixing it with more space. Ask me how I know… |
Three screws and two bolts.
its WAY easier to work on that wiring without the tray _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Murt Samba Member
Posted: Tue Nov 08, 2022 12:29 am Post subject: Re: Easiest way to get to Speedo wiring |
How do you know ?
Seriously, I've just got one of Speedhut's Classic VW Bus combo units (Speedometer/Tacho) any tips/photos that may help with the swap would be greatly appreciated
I previously had the Speedo in my 65 Beetle refurbished by Thorsten who is here on Samba, and he did an absolutely fantastic job.
But this time I wanted something different for the Bus, so went with the Speedhut unit, as wanted a Tacho, but not on the dash ? or in a little pod under it.
I did ask them if I could have the Gen/Oil lights incorporated like the roughly edited photo below, but they said they were unable to add those, so just bought the standard combo unit
mastorna Samba Member
Posted: Fri Nov 04, 2022 1:21 pm Post subject: Re: Easiest way to get to Speedo wiring |
You likely can do the Speedo with the dash tray installed but it’s 3 screws and you’ll be so much happier fixing it with more space. Ask me how I know… _________________ 1959 Type II Mango SO-23
1962 Type II Kombi Light Gray
1963 Type II Standard Sunroof SWR\BG
1963 Type II Deluxe MG\PW |
ozark23 Samba Member
Posted: Fri Nov 04, 2022 12:35 pm Post subject: Easiest way to get to Speedo wiring |
I did search....but here we are....
I need to rewire my speedo after 17 years.....turn signal flashes the red bulb/alternator light.....
Do I need to remove the shelf, or remove the speedo....or just contort my body and do the wiring in place.
Thx for any suggestions. |
