Replacing Turn Relay with modern electronic
CapeBuggy
CapeBuggy is offline
PostPosted: Wed Mar 29, 2023 3:43 pm    Post subject: Re: Replacing Turn Relay with modern electronic Reply with quote
Took me 5 minutes to swap the relay out. Had to wire a ground to terminal 30. Will be using a relay to get the indicator light to work. Using the KB terminal of the new blinker relay to power the generic relay to switch ground for the indicator. Should work....!
CapeBuggy
PostPosted: Tue Mar 28, 2023 1:12 am    Post subject: Re: Replacing Turn Relay with modern electronic Reply with quote
Dale M. wrote:
Your link is broken.... Did you mean this...
https://www.amazon.com/dp/B0748X9FY9?tag=namespacebran131-20
https://empius.com/alternative-part/211-953-215c-211-953-215c/
Believe terminals are... Further research required!...
"DIN" Numbering
31=Ground
49=Flasher IN (12 volts in(?))
49a=Flasher OUT (flashing 12 volts out(?))
K1=indicator lamp
That is the one Dale, thank you very much. Will wire it up and respond back here with a quick tutorial.
Dale M.
Dale M. is offline
PostPosted: Mon Mar 27, 2023 5:29 pm    Post subject: Re: Replacing Turn Relay with modern electronic Reply with quote
"DIN" Numbering
31=Ground
K1=indicator lamp
CapeBuggy
PostPosted: Mon Mar 27, 2023 3:12 pm    Post subject: Replacing Turn Relay with modern electronic Reply with quote
Can anyone point me in a direction on how to wire the replacement turn relay on a 68 chassis. I purchased this one
https://www.amazon.com/dp/B0748X9FY9?psc=1&ref=ppx_yo2ov_dt_b_product_details
The original VW seems to be dead so need to get these up and going. Have searched high and low on internet but can't find anything specific. Thanks!
