Ausdingo Samba Member
Posted: Fri May 26, 2023 11:09 am Post subject: Re: Rewiring a 70 |
Thank you for all your replies, really appreciate it
No yellow fuse box:) |
HarryFD Samba Member
Joined: February 24, 2012 Posts: 843 Location: Portland, OR
Posted: Fri May 26, 2023 11:05 am Post subject: Re: Rewiring a 70 |
| Ausdingo wrote: |
Hello all
So just got a new full set of wiring for my 70 bus. I have fed main loom through to front. The old fues box and wires were taking off before I got it. Starting from scratch. and not good at wiring diagrams, what and where do the main power wires from back to fuse box go? Is it best to wire up main wires first (12 Volt) from battery first, then wire ancillary up to fuse box (Lights ect)? Sorry for the basic questions, just very lost in this effort. I managed to wire up rear lights (License plate), just the nightmare of fusebox begins from scratch.
Appreciate all your help in advance. |
See my comments above.
I hope you do not have the self destructing yellow fuse box. _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1971 Jaguar XKE 2+2 V12 Coupe
1973.5 911 Targa
2009 MB C300 |
Posted: Fri May 26, 2023 11:04 am Post subject: Re: Rewiring a 70 |
| busdaddy wrote: |
Looks like it goes to the headlight switch:
Take that JPG down to your local office store and have them blow it up and print/laminate it, buy a grease pencil or dry erase pen while you are waiting, then you can highlight a particular circuit to focus on and forget about the background noise. |
Have them print it up as a "D Size" Drawing (i.e. 22x 17). Make 2.
German Car wiring is not like American Car wiring. Study the drawing carefully.
For German cars: Typically power goes to the switch, then to the fuse box and then to the controlled device.
For American Cars: Power goes to the fuse box and the ignition switch. The ignition switch then goes to the fuse box. Power then goes through the fuses to the switch and then on to the controlled device.
The color codes mean something as to the purpose of the wire.
Lots more.
If the OP does not feel comfortable with how this works, they should have a pro take care of it. _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53222 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri May 26, 2023 9:54 am Post subject: Re: Rewiring a 70 |
Take that JPG down to your local office store and have them blow it up and print/laminate it, buy a grease pencil or dry erase pen while you are waiting, then you can highlight a particular circuit to focus on and forget about the background noise. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri May 26, 2023 9:27 am Post subject: Rewiring a 70 |
Hello all
