baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2037 Location: Wichita, KS
Posted: Mon Nov 27, 2023 7:02 am Post subject: Re: Running a horn ground in the steering shaft on a 1971 Super |
SadKingBilly wrote: |
THe shaft is NOT grounded. Perhaps I have an early Super? |
It would be pretty hard for the steering wheel shaft of a Super Beetle not to be grounded to the chassis, on account of how it's attached to the steering box (i.e. direct connection - no rubber coupling disc). Plus think that the upper shaft is guided by a metal bearing, which is also in contact with/grounded in the steering column housing as well (? - not 100% sure on that).
In any case, have you tested your steering shaft for continuity between itself and another ground point on the chassis? If your meter shows continuity, then your steering shaft is properly grounded. _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
SadKingBilly Samba Member
Joined: November 25, 2023 Posts: 3 Location: Pawleys, SC
Posted: Sun Nov 26, 2023 10:36 am Post subject: Re: Running a horn ground in the steering shaft on a 1971 Super |
glutamodo wrote: |
Well, all Supers have a double U-joint coupling at the end of the steering column shaft. It's not like Deluxe ("standard") models where it was just one long shaft that a wire could and was run down.
1971 had an upper column assembly which handled the grounding and there was a contact plate bolted to the bottom of the classic-looking steering wheel, which provided the ground by a wiper contact built into the cancel ring which contacted a corresponding brass tab on the turn signal switch and giving the horn it's contact point through one of the holes in the steering wheel hub.
Perfect. Thank you VERY much! |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26530 Location: Douglas, WY
Posted: Sun Nov 26, 2023 8:38 am Post subject: Re: Running a horn ground in the steering shaft on a 1971 Super |
_________________ Andy T.
"What is Glutamodo, Horror of Toyko, besides total, fiendish, quality-a-you brain!" |
Posted: Sun Nov 26, 2023 4:26 am Post subject: Re: Running a horn ground in the steering shaft on a 1971 Super |
baldessariclan wrote: |
The horn wiring on 1971 and later model year Beetles doesn't use a ground wire passing through the steering column shaft -- that's only for 1970 and earlier models, which had the steering wheel hub and shaft on the normally "hot" side of the horn system's switched ground circuit. In your 1971 model it's reversed, and the steering column itself is now part of the final path to ground (i.e. on the normally "cold" side of the horn system's switched ground circuit).
So no need to worry about having to pass a grounding wire through your 1971 Super's steering shaft (assuming, of course, that the rest of your horn wiring system has remained in a basically "stock" configuration as well). |
Posted: Sat Nov 25, 2023 5:29 pm Post subject: Re: Running a horn ground in the steering shaft on a 1971 Super |
So no need to worry about having to pass a grounding wire through your 1971 Super's steering shaft (assuming, of course, that the rest of your horn wiring system has remained in a basically "stock" configuration as well). _________________ 1971 Standard Beetle — fairly stock / driver
Posted: Sat Nov 25, 2023 2:23 pm Post subject: Running a horn ground in the steering shaft on a 1971 Super |
Almost finished with a restoration, but it seems that my horn ground wire isn't there.
Do we HAVE to remove the gas tank to get to the universal joint or is there another way to get a ground wire down the steering shaft?
Apologies if there is a post about this, I did try searching.
THank you! |
