Lost69Convertible Samba Member
Joined: July 29, 2020 Posts: 487 Location: Rhode Island
Posted: Mon Nov 27, 2023 9:57 am Post subject: Re: Spring Plate Won't Line Up? |
I had longer bolts ready to go based on good Samba advice. But first I tried compressing the whole mess with a C-Clamp. Worked the clamp around and compressed in several places. To my surprise, the original bolts engaged the threads and tightened.
I did the above BEFORE bolting the spring plate to the diagonal arm. From your picture, looks like you have these two bolted together now. _________________ 1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4646 Location: Oklahoma City, OK
Posted: Mon Nov 27, 2023 6:51 am Post subject: Re: Spring Plate Won't Line Up? |
It is easier to first losely attach the cover plate withthe four bolts, then lift the spring onto the pad. |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 10977 Location: Huntington Beach, CA
Posted: Sun Nov 26, 2023 6:30 pm Post subject: Re: Spring Plate Won't Line Up? |
If the rubber is dry, it may be fighting you. Spray those donuts down with some silicon lube or use silicon paste. Be generous with the paste! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
BigTimeSal Samba Member
Posted: Sun Nov 26, 2023 5:06 pm Post subject: Re: Spring Plate Won't Line Up? |
runamoc wrote: |
I used longer bolts to 'pull' the bushing holder in till the regular bolts would reach |
Alright I'll give it a shot then, I've already tried that with some "longer" (~2.5") bolts but it's worth another shot with something even longer. Thanks gents. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 10851 Location: Oregon
Posted: Sun Nov 26, 2023 4:27 pm Post subject: Re: Spring Plate Won't Line Up? |
runamoc wrote: |
X2 This is the way I install "spring plate" torsion covers. _________________ I have learned over the years.
Buy Once, Cry Once!
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6039 Location: 37.5N 77.1W
Posted: Sun Nov 26, 2023 4:21 pm Post subject: Re: Spring Plate Won't Line Up? |
I used longer bolts to 'pull' the bushing holder in till the regular bolts would reach _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Posted: Sun Nov 26, 2023 4:02 pm Post subject: Spring Plate Won't Line Up? |
I'm in the process of getting my '74 back to stock, which means bringing it back up to stock ride height. I adjusted the swing axel, but now I cant get the spring plate back on and lined up. Any tips/advice?
