MarkWard Samba Member
Joined: February 09, 2005 Posts: 19073 Location: Retired South Florida
Posted: Mon Apr 22, 2024 7:47 am Post subject: Re: Syncro shifter question about R & G |
This picture seems to help some members. The factory manual is hung up on measuring to the right of the shift tab. The clearance that gets you a better shift is how the l/s tab compares to the above picture. This is a 4 speed in neutral, but it’s the same for a syncro. I can visually hit this point on the splines, but I used to attach a bungee cord to the shift lever and the passenger door pull. I’d slip a quarter between the l/s tab and the shifter box. Tighten the clamp and be done. |
dougnlina  Samba Member
Joined: January 19, 2016 Posts: 316 Location: San Francisco, CA
Posted: Mon Apr 22, 2024 6:39 am Post subject: Re: Syncro shifter question about R & G |
| gertiebob wrote: |
| Mine is currently so aligned. I use the block! Gears engage perfectly. No misalignment, grinding or other issues. Just the shhhhhhh noise and only in R and G. |
Sounds like it is one click too tight against the R-G Gate in the shifter box, putting force on the stickshift while in gear will make such noises. +1 they will go away when you disconnect the shifter _________________ "Grover" a '87 Syncro Poptop 1.8T
"Olive" a '60 Ragtop Beetle (retired)
"Kermit" '79 Westfalia (retired)
"Patches" '72 Beetle (retired)
"Wilbur" '69 Camper (retired)
"Bernice" 67 Beetle, My first love, (Also Retired) |
gertiebob Samba Member
Joined: February 23, 2015 Posts: 176 Location: Seattle
Posted: Sun Apr 21, 2024 5:51 pm Post subject: Re: Syncro shifter question about R & G |
4Gears4Tires Samba Member
Posted: Sun Apr 21, 2024 5:27 pm Post subject: Re: Syncro shifter question about R & G |
I was having an issue with shifting into R and G and I resolved it by creating a 22mm block of wood and aligning my shifter properly. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
Posted: Sun Apr 21, 2024 5:19 pm Post subject: Re: Syncro shifter question about R & G |
Thanks for thoughts Mark. Here’s another clue. Simply pushing down on the shifter knob while G is engaged and car moving quiets the noise.
I would like one day to see a Syncro transmission disassembled to get a better idea how it works. I understand principles and most terms but not how it all works in function. |
Posted: Sun Apr 21, 2024 3:08 pm Post subject: Re: Syncro shifter question about R & G |
| From memory Granny and Reverse share the same hub. You maybe applying pressure up front, but it is translating into that hub quieting the assembly. Also, G and R are in a different section of the transaxle. My hope it’s external. |
Posted: Sun Apr 21, 2024 1:05 pm Post subject: Re: Syncro shifter question about R & G |
Never thought of that. I’d need to find an empty parking lot.
However, I will say that if I move the shifter knob to the right while moving, help shifter hop over the lockout while staying in granny, noise disappears.
PS: noise is kind of a shhhhhhhh. Changing with speed while in G and R. |
Posted: Sun Apr 21, 2024 11:48 am Post subject: Re: Syncro shifter question about R & G |
| Can you temporarily drop the shift rod off the transmission, manually select G or R at the ball lever and see if the noise is present? You can temporarily tie wrap the shift lever up to keep it from dragging. This will isolate the shift mechanism completely. A noise while moving is not a common symptom of a shift linkage adjustment. |
Posted: Sun Apr 21, 2024 11:19 am Post subject: Syncro shifter question about R & G |
This has me stymied. My Syncro shifts fine into all gears. However, in R and G, there is a “rubbing” noise as the van moves. Also there is a feeling like the shifter tabs are too tight against the “back” of the R/G lockout plate while in R and G.
So, shifts into R or G fine, stays in gear fine but it just feels (and sounds) wrong. Adjusting away from this makes other gears problematic.
All newish shift linkage parts end to end. Well greased and clean.
Thanks for help.
PS: I do know how to adjust at the spline, etc. I believe all is correctly assembled. …but something is off and I suppose it’s me. |
