Dan22 Samba Member
Joined: August 30, 2019 Posts: 687 Location: Battle Ground, WA
Posted: Sun Sep 29, 2024 9:21 pm Post subject: Re: No brake lights |
How about power to the brake light switch, and with the brakes on, test the switch. Power from there goes straight to the turn signal switch. _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11393 Location: Huntington Beach, CA
Posted: Sun Sep 29, 2024 6:12 am Post subject: Re: No brake lights |
Check for power. You should have full battery voltage at one wire, with the key in the run position.
If so, attach a jumper wire to bridge the two wires together and see if the lights come on. _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Davidoliver Samba Member
Joined: May 08, 2021 Posts: 5 Location: Santa Clarita, California
Posted: Sun Sep 29, 2024 5:31 am Post subject: No brake lights |
I have read many post on electrical issues regarding tail lights and brakes light. I am by no means an expert. Probably more dangerous than good. Here is my issue. I have cleaned all connections, fuses, connectors, etc. I have tail lights and I have left and right turn signals working in both the front and back. I have installed a new turn signal switch and turn signal flasher (we) I have a new master cylinder and switch and I believe I have bled all the air out of the system, but when I press the pedal I have no brake lights.
Can someone make a suggestion as to what I should do next. Thank you all in advance. |
