Question: What to look for when buying a used engine stand
aeromech
aeromech is offline
PostPosted: Mon Jun 02, 2025 3:52 pm    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
I don’t use it enough but do try to change the oil every year. I might be thinking of selling it but not sure
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent Premium Member
SGKent is offline
PostPosted: Mon Jun 02, 2025 3:33 pm    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
my berg had a drain but it was cast into one of the ends. The question is do you use it enough in summer to need an oil change? I lived 90 miles north of you when I had the 1971 for all those years, and with the deep sump, the oil in winter never heated up so I had to take it off in winter and put on in late spring.
aeromech
aeromech is offline
PostPosted: Mon Jun 02, 2025 2:47 pm    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
Glenn,
I’ve got the same deep sump as you. I’ve considered adding a drain plug. What do you think?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Jun 02, 2025 1:17 pm    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
How so you build a short block when the case is split? I wouldn't trust 2 bolts with minimal flange to hold it and not crack the engine flange.
A 2 arm yoke works well and can hold a fully dressed engine. If you are unsure, get a 3 arm.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Kudagra
Kudagra is offline
PostPosted: Mon Jun 02, 2025 1:11 pm    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
aeromech wrote:
I’m not digging that idea.
I mean..it works.
I get using what you have and making things work...
But, through the hard way, Ive found you will be miles ahead using the right tool for the job.
Its been some expensive lessons.
Everything burns if you get it hot enough.
Kudagra
Kudagra is offline
PostPosted: Mon Jun 02, 2025 1:08 pm    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
SGKent wrote:
It looks like there is even room to add the clutch while it is off. Only caveat I would give is that make sure the engine stand it is used in will support the weight because it is longer than the other stands. I have a 4 yoke made 10 - 15 years ago by the Porsche guy who passed away a while back, and fully dressed a T4 causes my hefty engine stand to flex. Adding length would make it worse. But, that looks like a really nice product.
Oh yes plenty of room for the flywheel and clutch to be installed easily.
I have a 2000lb engine stand Ive had a 327AMC engine on. Those all forged engines are like 700lbs+ full dress. I dont think any VW engine (outside of a v10TDI) is going to bother it. I really do recommend it.
I have a 10ish year old 4 arm yoke that has had a few complete engines on it and it never even seemed stressed...but dealing with the clutch and flywheel is not a lot of fun.
aeromech
aeromech is offline
PostPosted: Sat May 31, 2025 9:04 am    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
poundman
poundman is offline
PostPosted: Sat May 31, 2025 6:25 am    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
olafwagner wrote:
I purchased the 'Vevor' engine stand from Amazon. I got the 1300 lbs version, not because of its carrying capacity, but rather because this one specifically has the 'U-shaped' footprint, which allows me to put something directly underneath to catch oil/dirt etc.
This stand, however, doesn't fit well onto the VW engine as is. So I 3D printed some spacer tabs that fit perfectly onto the case, and over the protruding lip as well. (I printed these with basic PLA, but with 100% infill). (Yes, I can already feel many people on this forum's eyes rolling, but seriously under compression these parts are more than strong enough).
The next problem was that the holes in the black arms are much bigger than M10 bolts, so I 3D printed some sleeves to fill this space. (also in basic PLA with 100% infill).
The final piece was that with the original hole locations, the mounting arms were spread too far out, so I drilled a second set of holes more 'inward' on the mounting arms.
I purchased two M10x120mm bolts for the two upper holes, and use the existing M10 studs for the two lower holes, and mounted the engine. Everything is very sturdy.
Here are the pics...
Olaf has sent me the files to try.
Restoring a 1972 Bay Window Bus that has not be registered for the road since 1981.
Sugar Land, Texas
SGKent is offline
PostPosted: Tue May 13, 2025 4:34 pm    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
Kudagra
Kudagra is offline
PostPosted: Tue May 13, 2025 12:07 pm    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
poundman wrote:
Reviving this thread because I came across this samba classified. Looks like someone is making and selling a mount strong enough for T4 engine now. Anyone using one of these can comment?
https://www.thesamba.com/vw/classifieds/detail.php?id=2712920
Yeah thats Brian E at Type E motorsports in South Dakota. I was going to copy it and make one on a plasma table but I decided that was a jerk move and I just bought one from him. Its heavy duty and I wont even blink at putting a full dress vanagon engine on it. Its built with plenty of room to install the flywheel (one issue I had with my 4arm yoke). Its a superb piece and I couldnt be happier with it.
BTW...look at his other ads...all kinds of goodies that I feel compelled to purchase.
poundman
poundman is offline
PostPosted: Tue May 13, 2025 9:33 am    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
Sugar Land, Texas
poundman
poundman is offline
PostPosted: Sat Oct 26, 2024 6:33 am    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
olafwagner wrote:
Glenn wrote:
How are you gonna split the case with all 4 bolts being used?
Yep, that is the shortcoming of my setup. Fortunately, I don't intending to split the case at the moment (I am just addressing the exterior of the engine), however, I will keep my eyes open for the proper T4 engine cradle in the future...
I like your ingenuity. Would be great to share those 3D print files so others could follow your lead. Like you I don't plan to split my case now, just work on the externals.
Sugar Land, Texas
Mr. 010
Glenn is offline
PostPosted: Sat Oct 26, 2024 3:58 am    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
jjvincent wrote:
Take two of the bolts off and split the case. It's not like it's too heavy with the case and internals in it. If it is, then I guess I've been lucky.
With such little material, on the yoke, it can break the ears off the case.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Wildthings
Wildthings is offline
PostPosted: Fri Oct 25, 2024 11:54 pm    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
Most all VW engine adapters just use two bolts to attach the engine to the adapter, built heavy enough a two arm stand is going to be just as good as a 4 armed stand. A three armed stand might give the best strength to weight ratio though..
sodbuster
sodbuster is offline
PostPosted: Wed Oct 23, 2024 10:17 pm    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
This is my old floor mount dealership stand. This is the best picture I can find of it. I've had it since 1990. if you can find something like this go for it. But look for just the head and yoke and you can mount it to whatever your fabrication skills allow. Avoid the cheaper small tube "bench top" style that still seem to be around. those just offer disappointment. You want something stout you can roll around at the very least.
jjvincent
jjvincent is offline
PostPosted: Sun Oct 20, 2024 9:28 am    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
olafwagner
olafwagner is offline
PostPosted: Sun Oct 20, 2024 8:24 am    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
Mr. 010
Glenn is offline
PostPosted: Sun Oct 20, 2024 7:56 am    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
jjvincent
PostPosted: Sun Oct 20, 2024 7:53 am    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
Just the one from Harbor freight. I have one and have done lots of different engines on it. The biggest trick is to just make sure you have the right fasteners. Those are easy to find. VW motors are super light, so the harbor freight ones work. If they work on a cast iron V8, then a VW motor is no big deal.
One other suggestion, is when you assemble the stand, make sure you lube up the casters and wheels. That way, you can easily move it around. Same for the rotating surface for the stand. My hardest ones are inline 6's because so much of it's weight is above the centerline of the crank. Thus a longer pipe to rotate it, made that job easier.
olafwagner
PostPosted: Sun Oct 20, 2024 7:39 am    Post subject: Re: Question: What to look for when buying a used engine stand Reply with quote
