Looking for the owner of this van!
johnnytod
johnnytod is offline
PostPosted: Mon Dec 16, 2024 10:20 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
Ahwahnee wrote:
I guess you're looking for who bought it at auction?
https://hideautovin.com/en/vehicle/215682503/volkswagen--vanagon/WV2ZB0256HH024182
Ahwahnee, not sure where you dug this out, but I wish you could find the original owner with these skills
jeepboy_90
jeepboy_90 is offline
PostPosted: Sat Dec 07, 2024 9:14 am    Post subject: Re: Looking for the owner of this van! Reply with quote
It appears the original poster is the one who bought the van and looking for the previous owner for additional information?
AD: https://www.thesamba.com/vw/classifieds/detail.php?id=2718600
1988 Syncro Doka
1986 Syncro Tintop
1971 Haflinger LHD
1973 Haflinger RHD
4Gears4Tires
4Gears4Tires is offline
PostPosted: Sat Dec 07, 2024 8:03 am    Post subject: Re: Looking for the owner of this van! Reply with quote
Definitely looks like a great way to get a rebuilt transmission at the very least. I don't know if the wiring or motor is any good though. Does the FAS kit put the wiring and ecu in the cabin? Certainly the major engine swap bits of the engine swap like the carrier bar, oil pan, and transmission adapter plates look good.
Maybe it was a failed brake switch that caused the fire.
vanis13
vanis13 is offline
PostPosted: Fri Dec 06, 2024 9:01 am    Post subject: Re: Looking for the owner of this van! Reply with quote
tdivan82 wrote:
vanis13 wrote:
I thought FAS did only diesel conversations.
They also offer the 2.0 ABA engine.
Well there you go! Thanks for the education.
tdivan82 Premium Member
tdivan82 is offline
PostPosted: Fri Dec 06, 2024 6:39 am    Post subject: Re: Looking for the owner of this van! Reply with quote
- George
'82 Westy TDI (ahu)
'96 Passat TDI
vanis13
vanis13 is offline
PostPosted: Fri Dec 06, 2024 6:31 am    Post subject: Re: Looking for the owner of this van! Reply with quote
tdivan82 wrote:
vanis13 wrote:
Yeah, and I was thinking of it's FAS it is diesel which would less likely be a fuel fire.
How can you tell diesel from the photo? I guess the fact that the engine didn't burn is a pretty good clue.
It's giving off electrical fire vibes. Van seems to be well accessorized, so could be sketchy wiring / unfused circuit at the battery or fuse box.
Abscate wrote:
Hemp vent block off plates
I think those are palm trees...
tdivan82 is offline
PostPosted: Fri Dec 06, 2024 6:17 am    Post subject: Re: Looking for the owner of this van! Reply with quote
- George
'82 Westy TDI (ahu)
'96 Passat TDI
vanis13
vanis13 is offline
PostPosted: Fri Dec 06, 2024 6:01 am    Post subject: Re: Looking for the owner of this van! Reply with quote
82westyrabbit
82westyrabbit is offline
PostPosted: Fri Dec 06, 2024 4:38 am    Post subject: Re: Looking for the owner of this van! Reply with quote
Thatโ€™s definitely a FAS engine conversion. The transmission is stock vw. It looks different because it has an adapter plate for the FAS engine conversion. The fire looks like it was in the front so it probably it wasnโ€™t the usual bad fuel lines. Someone had a lot of money it that van. The fire must have been devastating to them. On the bright side someone got a great deal on a FAS engine conversion and what looks like a rebuilt transmission. John
Abscate Premium Member
Abscate is offline
PostPosted: Fri Dec 06, 2024 1:46 am    Post subject: Re: Looking for the owner of this van! Reply with quote
Very Happy
vanis13
vanis13 is offline
PostPosted: Fri Dec 06, 2024 1:03 am    Post subject: Re: Looking for the owner of this van! Reply with quote
ALIKA T3 wrote:
I can't access the pics anymore but it was a Vanagon transmission, just clean.
This should be all of them if not they are in my gallery
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Dec 05, 2024 11:10 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
vanis13
vanis13 is offline
PostPosted: Thu Dec 05, 2024 8:03 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
Mile High Puma wrote:
The transaxle looks heavy duty. Is that a Subagears unit?
I was wondering about that transaxle. Mine has a diff bellhousing....and man, it's clean!
Mile High Puma
Mile High Puma is offline
PostPosted: Thu Dec 05, 2024 7:30 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
1965 Velvet Green DC
1990 Westfalia Syncro
tdivan82 is offline
PostPosted: Thu Dec 05, 2024 3:00 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
Front left corner looks the worst, the left headlamp looks much worse than the right, and large puncture in the sheet metal next to the antenna hole. Maybe the fire started in the Fusebox area?
- George
'82 Westy TDI (ahu)
'96 Passat TDI
SLOWoody
SLOWoody is offline
PostPosted: Thu Dec 05, 2024 2:07 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
Looks like the fire was concentrated in the front of the van. Much more fire damage up front and the area around the radiator is torn up.
83.5 Westfalia, GW 2.3L w/ GW EFI, 4 speed
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Thu Dec 05, 2024 12:57 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
tdivan82 wrote:
What happened to that poor westy? Drivers door looks like a dinosaur tried to get inside.
This is another example of the Fire Dept going nuts trying to locate the fire source. The door must have been locked and they went to town prying it open (why they didn't just go though the window is a mystery) Note the damage to the front as they tried to open the front hood. Rolling Eyes
Currently:
All that's needed for evil to prevail is for good people to do nothing.
tdivan82 is offline
PostPosted: Thu Dec 05, 2024 6:11 am    Post subject: Re: Looking for the owner of this van! Reply with quote
- George
'82 Westy TDI (ahu)
'96 Passat TDI
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Dec 04, 2024 10:49 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
Surprised it sold fur 875
Interesting shot of the engine and tranny, I don't recognize it. Any ideas what it is?
Looks like a FAS kit to me.
vanis13
vanis13 is offline
PostPosted: Wed Dec 04, 2024 10:44 pm    Post subject: Re: Looking for the owner of this van! Reply with quote
