Points not "mating"
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Mon Dec 09, 2024 7:28 pm    Post subject: Re: Points not "mating" Reply with quote
Some points are better than others. Some points require them to be bent in order to flatten the mating surface. A picture would help to understand what is needed. Make sure nothing is under the flat part that screw holds down.
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sun Dec 08, 2024 7:26 am    Post subject: Re: Points not "mating" Reply with quote
Sounds like you are describing a big cap 40hp distributor issue. On a big cap 40hp distributor the easiest way to work on points and condenser is to disassemble the distributor and work from a better angle. There's a reason the design only lasted a few years.
Roads Scholar
Member# 2059
Schnitzelfuss
Schnitzelfuss is offline
PostPosted: Sat Dec 07, 2024 4:39 pm    Post subject: Re: Points not "mating" Reply with quote
A picture would help us here.”Meeting 60%” means…?
trike newbie
trike newbie is offline
PostPosted: Sat Dec 07, 2024 2:08 pm    Post subject: Points not "mating" Reply with quote
"64 beetle ,40hp. Points were pitted so I took them out, filed them and replaced the condenser . When re installing I couldn't get the points to meet fully. Two piece points. I got a new set and the fiber washer under the pivot looked better , but when installed the contacts are only meeting about 60%. How the spring is clamped with the wires seems to change the height.
HOW do you tighten the bolt to secure the wires? No room in distributor . If I do it outside, It won't go down all the way on pivot shaft .
