Stock height irs swap?
pyrOman
Fire Master
pyrOman is offline
PostPosted: Fri Feb 07, 2025 5:22 pm    Post subject: Re: Stock height irs swap? Reply with quote
Check out my pictures. It’s not an easy bolt on affair. Some welding and machining work needs to be done. Cool
https://www.thesamba.com/vw/forum/album_search.php...t_dir=DESC
JDub113
JDub113 is offline
PostPosted: Fri Feb 07, 2025 8:29 am    Post subject: Re: Stock height irs swap? Reply with quote
pyrOman wrote:
Type 2 IRS Cool
What’s the axle angle when it’s on the ground? A picture would be fine too. I’m interested in doing this.
84 Wolfsburg Edition Westy
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed Feb 05, 2025 9:18 pm    Post subject: Re: Stock height irs swap? Reply with quote
Type 2 IRS Cool
chrisflstf
chrisflstf is offline
PostPosted: Wed Feb 05, 2025 7:33 pm    Post subject: Re: Stock height irs swap? Reply with quote
I had asked brian at type e about stock heigth irs, but honestly dont remember his answer, but he is the one to ask. Post if you do
Some info here
https://www.thesamba.com/vw/forum/viewtopic.php?t=777663&highlight=irs
Andy57
Andy57 is offline
PostPosted: Wed Feb 05, 2025 6:19 pm    Post subject: Stock height irs swap? Reply with quote
Hello, I was curious If anyone has done a stock height irs swap in a split bus. I have done 2 irs swaps in Splits but both were lowered. I really like the irs swap. Cheaper, easier and more reliable then the rgbs. I imagine cv axle binding is the issue? I plan to run 930 cvs and cv spacers. Not sure if that will be enough. Looking for any in site before I get in deep. I have a type E kit and I have used one before with great success.
