Early tdi 1z oil squirters testing.
karush
karush is offline
PostPosted: Thu Mar 06, 2025 8:15 pm    Post subject: Re: Early tdi 1z oil squirters testing. Reply with quote
Hello, thanks for the replies. The early check valves which were used in early 1z Tdi’s is what I have , they are different than the later check valves in that they do not have a restriction other than the size of the nozzle itself. Both have the spring/ball check valve , but The later check valves have a small hole drilled into the center bolt which further restricts flow and must delay the opening of the spring/ ball check valve.
Does anyone know why they made this change? Is it possible to retrofit the newer style check valves in my block if indeed, they don’t open until a higher pressure , thus helping out with hot idle lubrication. Thanks, Paolo.
?Waldo?
?Waldo? is offline
PostPosted: Thu Mar 06, 2025 1:22 pm    Post subject: Re: Early tdi 1z oil squirters testing. Reply with quote
They aren't supposed to leak at idle. The reason for the valve in them is to prevent them from lowering idle oil pressure. They would just be an open port otherwise. It might not be a big deal, though, depending on what your idle oil pressure actually is. I've tested them before with an injector pop tester with a swapped in lower pressure gauge. I believe the Mk2 Bentley gives the pop pressure, I don't recall if the Mk3 does. It was years ago, so the details are foggy.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Mar 06, 2025 12:40 pm    Post subject: Re: Early tdi 1z oil squirters testing. Reply with quote
you're fine
they are just barely pissing oil at that pressure. The fun begins at 2k/40 psi
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
DanHoug
DanHoug is offline
PostPosted: Thu Mar 06, 2025 11:34 am    Post subject: Re: Early tdi 1z oil squirters testing. Reply with quote
MarkWard wrote:
I don’t know the exact answer, but the springs probably have something to do with drain back, not opening pressure.
they are actually sold as 'check valves'!!!
https://techtonicstuning.com/product/20l-piston-squirter-check-valve/
-dan
www.thefixitworkshop.com
MarkWard
MarkWard is offline
PostPosted: Thu Mar 06, 2025 9:25 am    Post subject: Re: Early tdi 1z oil squirters testing. Reply with quote
I don’t know the exact answer, but the springs probably have something to do with drain back, not opening pressure. The engines had a higher volume oil pump and the nozzles are the restriction and it’s likely you aren’t loosing any oil pressure having them spraying all the time. This will bump your post.
karush
karush is offline
PostPosted: Wed Mar 05, 2025 8:14 pm    Post subject: Early tdi 1z oil squirters testing. Reply with quote
Rebuilding my tdi 1z, originally out of a 1996 Passat. I’ve removed the oil squirters and blown air through them. They all flow fine with no clogging but the spring loaded pressure check balls seem to have very light spring pressure. So light that they lift the ball from its seat and begin to flow almost right of the bat. (1-2psi) and by idle pressures of say 15 psi will be flowing strong for sure. Is this normal? Or do they wear out. I have the early kind squirter’s with a separate solid screw which fastens them to the block. Not the kind with a hollow single screw. Thanks, Paolo.
