That black wire...
Wildthings
Wildthings is offline
PostPosted: Fri Mar 14, 2025 6:26 pm    Post subject: Re: That black wire... Reply with quote
I typically do NOT connect it to the B+ post on the alternator and then bend it back and wire tie the bend in place making the entire wire dead. I have also just removed it from the harness. If you are one to add a bunch of electrical stuff then leaving it and just taping the free end off so you can easily use it as a 12v source is the way to go.
Lahucheapin
Lahucheapin is offline
PostPosted: Fri Mar 14, 2025 6:07 pm    Post subject: Re: That black wire... Reply with quote
Thank's to all!..
busdaddy
busdaddy is online now
PostPosted: Fri Mar 14, 2025 8:03 am    Post subject: Re: That black wire... Reply with quote
Yes, test network, tape it up since it's live all the time.
Слава Україні!
wagen19
wagen19 is offline
PostPosted: Fri Mar 14, 2025 4:12 am    Post subject: Re: That black wire... Reply with quote
Lahucheapin wrote:
Hi! I'm working on a 76 bus. And i saw that the wire harness from the alternator have 4 wires rather than ordinary 3 (DF, D+ and D-). What's this black wire do and where it go?
Thank's!
Black wire goes to test socket. Probably the same as for type 4.
https://www.thesamba.com/vw/archives/info/wiring/411_1972b_usversion.jpg
Lahucheapin
PostPosted: Fri Mar 14, 2025 3:37 am    Post subject: That black wire... Reply with quote
Thank's!
