94touring Samba Member
Joined: October 24, 2020 Posts: 665 Location: Tulsa - OK
Posted: Tue Dec 30, 2025 7:32 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
| Slight post bump to the up and coming changes. Currently about done installing EFI and will be going to TPS control for the water pump. The water/meth controller is the Harris HPC naturally aspirated controller I posted about earlier on. I have been using an on off switch and controlling the pump output with a basic motor controller. Works great but the advantage of the TPS is I can have the pump activate more accurately and increase pump output however I desire based on throttle position. Bench testing the throttle bodies the TPS at idle is 2v and 5v wide open. This actually won't work with the Harris controller because it actives at 2v, which means it will always be on. Also I don't want it to run at the full 5v or 100% pump output due to duty cycle limits of the pump and the potential to overheat the pump on hard drives pulling gear up grades for extended periods of time. Nor does the engine really need that much h20. The easy solution was just adding a volt controller between the TPS sensor wire to the Harris controller. Dialing down the input signal to a max of 3v gives a 2v reading at approximately 50% throttle and a 3.75v max giving 2v at about 25% throttle. Something between 25 and 50% throttle is going to work perfectly, I'll just have to mess with it once it's back on the road. It will ramp up flow under more load as desired, yet not max out the pump duty cycle. The plan is still build a motor with compression higher than pump gas will allow and toss this efi kit and TPS h20 setup on that motor. |
Posted: Sun Oct 12, 2025 4:05 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
| That's a cool spray bar you've made. I don't recall seeing an afr drop with just straight water, but I also didn't test much with it. |
Wreck Samba Member
Posted: Sun Oct 12, 2025 2:34 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
94 what a trip , at least you weren't stuck ,always pays to carry spares.
I sort of tempted fate with you when I mentioned not to have a touring engine that needs WM injection to just run correctly.
I did the 1/8 event but had minor issues with a throwing a belt , I didn't have enough time to experiment . I did one run with the water on, just straight water , it dropped the AFR from 12.5 to 12 . My ECU pulls CHT from a sender (Air intake sender) under the cylinders , so it doesn't read accurately . My times were not consistent (trying different tyre pressures ,launch rpm etc) so not able to check times etc .
When I get a bit more time I'll play with it some more.
Still had a good time , drove 2 hours out to the event . Pulled 183whp ,(PB on that dyno) PB 60 foot, 1.88 on street tyres and 8.48 at 82.5mph . drove home with no major issues . The Ghia is a porker about 1100kg , 2400 pounds.
Posted: Sun Oct 12, 2025 12:48 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
| Nice meeting you too! That 2nd pull I actually turned up the h20 and made 2 more ft/lbs of torque and the same hp. Bfb said he made a lot more without it. We'll have to ponder that one. Now that being said, I'd for sure notice seat of the pants loss of that much power spraying. If anything I've always felt like I gained a little extra. I suppose the small bump on the dyno concurs with that. |
Alexander_Monday Samba Member
Joined: November 09, 2007 Posts: 457 Location: Springfield Missouri
Posted: Sun Oct 12, 2025 11:50 am Post subject: Re: H20 injection naturally aspirated head temp test with results |
It was nice to meet you yesterday. Interestingly enough, BFB's sand rail made more HP with the H2O turned off. Something like 168HP IIRC. _________________ Danth’s or Parker’s Law:
“If you have to insist that you've won an internet argument, you've probably lost badly.”
Alexander_Monday->What were the rings gapped at?
bedlamite->Almost enough.
| andk5591 wrote: |
The original german engineers have attained sainthood and it is impossible to improve perfection.
Anything that anyone does to deviate from the original designs will be made to wrench on 20 year old Yugos with Harbor Freight tools in hell. |
Posted: Sun Oct 12, 2025 11:04 am Post subject: Re: H20 injection naturally aspirated head temp test with results |
Here's the latest info. I tried the 4 nozzle approach with a 30cc on each manifold runner. Did a 10 hour round trip drive to the Ozarks and did a dyno day that BFB hosted to test this setup. Used a 24psi check valve to keep it from pulling in h20 under vacuum. It works but not as good as the single 45cc nozzle above in the center of the stacks. Anything more than bare minimum flow gunks up the oil in no time. Evident from my large breather in place of the oil cap. I didn't set it up to flow continuously, just under some load and throttle, but I suspect it would be gunking oil up or on the ragged edge of it. It doesn't seem to cool any better either. So I'll be going back to the singular nozzle, even on the 2387 build.
The trip wasn't exactly uneventful. Lost 4th gear 5 hours away from home and on the final home stretch blew the belt. Grenaded so hard it took off a coil wire and wiped out a water line. Which was probably good because it shut off immediately so there was no time to cook the heads. I carry spares so was quickly back on the road to cruise in 3rd gear. That dyno we used seemed to read off, at least the HP numbers on the cars were all low. I did end up with one of the smoother curves from the ones I saw while I was there, so I'll take that victory. Minimal sidewinder dip with how I did my custom exhaust and tune. A 2276 with fk7 made 108hp and 190ft lbs for example.
Posted: Tue Sep 30, 2025 1:12 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
| Wreck wrote: |
I'm in the process of trialing some cheap brass greenhouse fogging nozzles .
I'll place them above the stacks (Injected NA) and see what happens . I've an 1/8 mile event next month , it normal gets warm (+30C) in the day . I'm interested to see if there is any difference in the time/speed etc . Just going to be using straight filtered tape water.
They come in different sizes , I'm starting with 0.004" (smallest) they give a nice fine spray , better than the aquamists I have now . Just need to make one more spray bar ( 10mm square aluminium rod )
https://www.ebay.com.au/itm/406032497193?chn=ps&am...1776442415 |
Had a moment to measure with the micro jets and the 30cc nozzles appear to be 0.007" |
Posted: Tue Sep 23, 2025 9:59 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
| Wreck- Running a solenoid in my case probably won't work, because they have duty cycles. If I'm running it continuous for long periods odds are it burns up the solenoid. What I can do however is just get a check valve with a rated cracking pressure higher than what the highest vacuum signal is at high rpm deceleration. The check valve in line now is only 5psi which keeps the tank from pushing h20 out the nozzles depending on how full the tank is versus the height of the nozzles. My plan is relocate that valve just off the pump and a higher psi check valve into the 4 port distribution block that feeds the nozzlss. The idea being the line between the pump and nozzles will maintain h20 in the line to be more responsive when the pump engages. |
Wreck Samba Member
Posted: Tue Sep 23, 2025 7:53 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
| you will also need a solenoid valve to stop the WM getting drawn in under vacuum when the system is not spraying ,if you haven't got one already. I used a cheap ebay valve . |
Posted: Tue Sep 23, 2025 3:41 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
| oprn wrote: |
| I have asked this before here but I will try again. Would it not be better all around to inject the water just below the carbs? |
Since I will be trying the 4 nozzle approach on the next build I went ahead and bought the extra parts I need. And since I have the parts I think I will see what four 30cc nozzles do on this 2180 at their lowest output. Will I get oil gunk or not spraying near continuous. I know that two 45cc nozzles on high doesn't work. I didn't bench test and time the 45s to see what they're putting out on high, but a graph online shows about 80cc at 200psi. I was using a 300psi pump on high output at the time, so I'll guess 100cc each. But then there's a percentage that doesn't make it's way into the intakes spraying above and that's where the math gets fuzzy. The 30cc nozzles gave me around 25cc at the lowest output on a 200psi pump. This will be using a 35% methanol mixture. I need to test out a spare set of manifolds on how to go about getting the nozzles mounted at the right angles and location so it's actually misting with airflow and not creating puddles and massive droplets. |
BFB Samba Member
Posted: Thu Sep 18, 2025 4:39 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
| Wreck wrote: |
ok, ok... now that that was brought up.... you know the misting systems they sell at like Lowes and such that you hang on your porch, hook to garden hose and it sprays a nice fine mist to cool you down? weeellll... I used one of those nozzles in my water injection set up. its been in operation for 5-6 years now and only issue ive had so far is that I was using the washer fluid that's the winter type , has 'anti freeze' in it and was clogging my jet. ( knock on wood )
its set up pre-carb and if I remember correctly the jet is .030 which was perfect for the cc's I needed. nice thing is that they aren't just a metering type jet but they have some shit inside that forces the water to spray in a cone pattern. down side to that is that its hard to clean...
its fed by a 12v pressure washer pump too.
ok, so I checked your link after I wrote this and the one I used is the same as these. apparently I was wrong about the size.
I did solder that jet to the fixture so it wouldn't unscrew and get sucked into the carb. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Posted: Thu Sep 18, 2025 4:24 am Post subject: Re: H20 injection naturally aspirated head temp test with results |
Wreck- I have to go back to my day job and out of the country today, but when I get back will verify what size the 30cc nozzles are. I have a micro drill bit kit I got to "clear" the nozzles when I was bench testing and cleaning up tap water gunk. I think the 30cc nozzles from snows are 0.1mm or
004".
I bumped timing up 2° like Torben just mentioned as well. Let us know if you see a difference in times. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7971 Location: Videbaek Denmark
Posted: Thu Sep 18, 2025 3:38 am Post subject: Re: H20 injection naturally aspirated head temp test with results |
| Wreck wrote: |
Remember, when injecting water you need slightly more timing, so you will have to "eyeball"the extra need for timing in relation to the injected amount of fuel. You can maybe find answers to that on Einstein Motors. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Wreck Samba Member
Posted: Thu Sep 18, 2025 1:57 am Post subject: Re: H20 injection naturally aspirated head temp test with results |
Posted: Mon Sep 15, 2025 9:38 am Post subject: Re: H20 injection naturally aspirated head temp test with results |
| oprn wrote: |
Yes it would be. But, unless you're driving a fire breathing dragon naturally aspirated engine, you start injecting too much. Then you get water build up in the oil that shows itself on the valve covers. It would work fine if you spray in short burst. Drag race, the occasional hill where you need cooling. If you're spraying on a continuous or near continuous amount, it's too much h20. Perhaps total seal rings would solve oil contamination with excessive h20 spray. On the 2387 in the works I intend to try four individual nozzles and total seal rings. I won't know if it works until the first time I pop the valve covers after a couple days of driving. If it doesn't work then back to a single nozzle on each side. Ideally I can run the four smallest nozzles, if so I may relocate them to the manifolds.
Where this could work with a lot less fuss would be a single carb. Then you get to run a single nozzle in whatever size works best for your engine displacement and cooling needs. The complexity is with twin carbs. |
oprn Samba Member
Joined: November 13, 2016 Posts: 15279 Location: Western Canada
Posted: Mon Sep 15, 2025 9:21 am Post subject: Re: H20 injection naturally aspirated head temp test with results |
I have asked this before here but I will try again. Would it not be better all around to inject the water just below the carbs? _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Mon Sep 15, 2025 7:55 am Post subject: Re: H20 injection naturally aspirated head temp test with results |
| Quick update with some info to pass along. I was collecting the h20 that didn't make it into the intakes and running it to a container and then dumping it back into the main tank, filtering it of course. I'm ditching this approach. After pulling things out and inspecting the system after that 4k mile trip, I noticed the filters at the nozzles caught a fair amount of gunk. Appears to me some oil and other microscopic particles find their way through and begin to clog the filters. I certainly don't have this issue on my water injection filters on my rx7. I will just stick with the drain ports at the base plates of the intakes that have a small plastic line that allows the overflow to drip underneath the engine. |
Posted: Thu Sep 04, 2025 8:58 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
| I've been doing water injection outside the VW world for a good 8 years now. I'm not so worried about a line burst, or even a pump failure given all the bench testing for duty cycle limits and running the pump nearly continuous for 4k miles the past month. A clogged jet because of their size is a concern, though I think I caused the issue this time with the wrong gallon of water. I just happened to have about 30 gallons of water in the back because of burning man and grabbed a wrong one. |
sidemarkers Samba Member
Posted: Thu Sep 04, 2025 8:14 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
| Wreck wrote: |
But if you are WOT up a long hill with a semi trailer on your tail and for some reason a nozzle blocks or line blows then it can go bad very quickly . |
Yeah, the engine compartment might get a little water spritz, now juxtapose that statement with a fuel line.
Even with all the stories of VWs burning up due to fuel lines or filters or fittings, the society as a whole has a bit of hydrophobia to work through.
Manufacturers primarily focus on cooling the area around the outside of the combustion chambers with water, there are however distinct advantages to directly cooling the insides.
Aircooled on the outside and watercooled on the inside. |
Posted: Thu Sep 04, 2025 3:56 pm Post subject: Re: H20 injection naturally aspirated head temp test with results |
| I don't disagree with that. There is risk involved for a long road trip vehicle if I end up doing it this way. |
