Dropped Spindles
Ondri
Ondri is offline
PostPosted: Wed May 21, 2025 8:43 am    Post subject: Re: Dropped Spindles Reply with quote
Alright, then i will give it a try.
Thank you for the help.
DaveB9
DaveB9 is offline
PostPosted: Sun May 18, 2025 12:12 pm    Post subject: Re: Dropped Spindles Reply with quote
No need to change balljoints, though worth checking them while you have it apart. If the dropped spindles are for discs, the bearings should be the same.
Ondri
Ondri is offline
PostPosted: Sun May 18, 2025 10:33 am    Post subject: Dropped Spindles Reply with quote
Hello, i just bought a Ghia from 1970 and i want to drop it in the front with dropped spindles. Do i need to change wheel barings and ball joints or can i use the once that are on the car? It has disc brakes in the front.
