Multi69s Samba Member
Joined: January 24, 2006 Posts: 5537 Location: Lefty, CA
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 1040 Location: San Juan Islands
Posted: Thu May 22, 2025 2:01 pm Post subject: Re: Electric AC Compressor and 100 AMP alternator |
There's a good thread on the 914 World, same subject.
http://www.914world.com/bbs2/index.php?showtopic=374526
Looks like a 175+ Amp alternator would be preferred along with the largest capacity battery you could fit?
Either way, 100amps isn't enough.
Watching this myself as I wouldn't mind installing Electric AC in my Bug. _________________ When I set my timing, why do I flush, then take a pee? |
mjrpoulton Samba Member
Joined: December 28, 2011 Posts: 6 Location: Chester UK
Posted: Thu May 22, 2025 12:15 pm Post subject: Re: Electric AC Compressor and 100 AMP alternator |
When I fitted electric AC to a T3 engine KG last year I fitted an on/off switch to the evaporator electrical feed which also powered a remote relay to allow the main power feed from the battery to energise the AC - like a hard start relay but much bigger!
Like you I fitted a 100amp alternator and upgraded the supply from it by running a heavier cable to the starter (which obviously feeds the battery). I also fitted a 60ah battery (upgraded 411/412 size) which just fits in the under rear seat area.
I did not like the thought of the main power feed from the battery to the AC inverter at the front of the car being live all the time as shown in the fitting instructions hence the switching solution.
Had no trouble with discharge from battery but as with an engine compressor on a carburettor engine, the load on the alternator does drop the idle speed, so I have fitted an idle stop solenoid triggered from the same main power relay. |
halfassleatherworks Samba Member
Joined: December 09, 2018 Posts: 771 Location: Reno NV
Posted: Thu May 22, 2025 8:36 am Post subject: Re: Electric AC Compressor and 100 AMP alternator |
1,2 or 3 battery's it does not matter, if the alternator does not put out more then what is used then you will discharge the batters, and will cook the alternator trying to keep up. |
talljordan Samba Member
Joined: January 10, 2012 Posts: 1063 Location: San Francisco, CA
Posted: Wed May 21, 2025 5:34 pm Post subject: Re: Electric AC Compressor and 100 AMP alternator |
With 320A, you are going to melt the wire that goes to the battery to charge it before anything else. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13946 Location: White Mountains Arizona
Posted: Mon May 19, 2025 6:26 pm Post subject: Re: Electric AC Compressor and 100 AMP alternator |
What sorta engine is going to be turning the power source...altenator. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4119 Location: Georgia
Posted: Mon May 19, 2025 12:43 pm Post subject: Re: Electric AC Compressor and 100 AMP alternator |
Everything electrical in a car runs off the battery. The alternator is there to keep the battery charged. If your battery is dropping in voltage you need a larger capacity alternator.
WOSP is developing 120, 175, 250 & 320 amp alternators but aren’t available for sale yet.
https://www.wosperformance.co.uk/alternators/alternators-search?p=1&mid=62&c=2&mo=135062 _________________ Volkswagen!
(Compression 8.7:1) |
vamram  Samba Member
Posted: Mon May 19, 2025 10:59 am Post subject: Re: Electric AC Compressor and 100 AMP alternator |
I read somewhere of another ACVW owner installing a 2nd battery for use by an electric AC. I also thought that the biggest alternator available was 90 amps.
Can you provide a more detailed description of the system you installed and how everything is mounted and connected? Pictures would be nice too. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
nickonickolaw Samba Member
Joined: April 10, 2019 Posts: 70 Location: Torrance CA
Posted: Mon May 19, 2025 8:24 am Post subject: Electric AC Compressor and 100 AMP alternator |
Hi guys, I recently installed an AC unit powered by an electric compressor.
I also put a 100 Amp alternator in that I ordered from the UK.
My question here is, why is the AC still drawing power from the battery?
do i need a bigger battery? positive terminal?
please send links if possible thanks! |
