| I'm familiar with the HAPI engine, and... |
| it's not worth fixing |
0% |
[ 0 ] |
| it's worth fixing, get a crank |
0% |
[ 0 ] |
| it's worth fixing, the crank is not the problem, read my comment |
0% |
[ 0 ] |
| Total Votes : 0 |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3668 Location: West Coast (Michigan's)
Posted: Tue May 27, 2025 10:25 am Post subject: Re: HAPI Magnum 2.2L, SCAT heads , dual ignition airplane engine |
This would be better asked in the Performance forum. Those guys would know about such things. _________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
oprn Samba Member
Joined: November 13, 2016 Posts: 15215 Location: Western Canada
Posted: Mon May 26, 2025 4:23 am Post subject: Re: HAPI Magnum 2.2L, SCAT heads , dual ignition airplane engine |
I have no idea what issues the HAPI engines had. What are you going to use the engine for and what will it be installed in? There are way too many unknowns here.
By the way, in a type 1 VW engine it is not possible to get 2.2 L displacement with a stock VW crankshaft. It's got somebody's stroker crank in there... _________________ Our cars get old, we get old but driving an old VW never gets old! |
Harvey Cheyne Jr Samba Member
Posted: Sun May 25, 2025 8:03 pm Post subject: HAPI Magnum 2.2L, SCAT heads , dual ignition airplane engine |
I have been told HAPI went out of business because they went with bigger displacement without going to a bigger crank, and as a result, some cranks broke
Is this true?
If it is true, I have to split the case and find out which crank I have, right ? (this engine is supposedly pickled NOS, never run, and has no documentation with it)
If this is true, what crank do I need ?
Will the bigger crank have bigger main bearings, longer stroke, or both ? What was the crank failure mode and what's the fix ?
Also, supposedly they used aluminum flywheels which also broke, so I just need a stock steel flywheel, right ?
I am not a VW guy but i want to keep this engine and run it, because other than the crank issue, this engine and HAPI as a company have a great reputation
Should this thread be in a different forum ? 'Off road" seemed the closest match |
