kamzcab86 Samba Moderator
Posted: Fri Aug 01, 2025 4:49 pm Post subject: Re: Gowesty gas tank vs others? |
crazyvwvanman wrote: |
There was a 20+ gal VW RSA tank you could buy but they went NLA years ago. |
Except even they have the stupid "saddle" in the center.  _________________ ~Kamz
2016 Golf GTI S
tdivan82  Samba Member
Joined: September 17, 2023 Posts: 272 Location: Virginia
Posted: Fri Aug 01, 2025 4:45 pm Post subject: Re: Gowesty gas tank vs others? |
Very cool, yes that's exactly what I'd like as an upgrade. Too bad nobody is selling them any more. Someone should locate one and produce a run of them. A right profitable venture that would be. You could probably sell tens of them. TENS!! _________________ - George
'82 Westy TDI (ahu)
'96 Passat TDI |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10374 Location: Orbiting San Diego
Posted: Fri Aug 01, 2025 3:36 pm Post subject: Re: Gowesty gas tank vs others? |
I knew a few people with them in their Vanagons.
Ken at Vanagain sold them at one time.
Not exactly bolt-in but not too difficult.
The tank simply extended back farther than the original tank.
edit: here are some old threads about them
https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
Mark
tdivan82 wrote: |
Its too bad these are all straight copies of the original design. Would be nice if someone made one that had a larger volume. 80 liters (21 gal) would be a worthwhile upgrade. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4405 Location: ABQ NM USA.... Except when not
Posted: Fri Aug 01, 2025 2:16 pm Post subject: Re: Gowesty gas tank vs others? |
tdivan82 wrote: |
I wonder if there would have to be a certification process for that? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Fri Aug 01, 2025 2:10 pm Post subject: Re: Gowesty gas tank vs others? |
Its too bad these are all straight copies of the original design. Would be nice if someone made one that had a larger volume. 80 liters (21 gal) would be a worthwhile upgrade. _________________ - George
'82 Westy TDI (ahu)
'96 Passat TDI |
Posted: Fri Aug 01, 2025 12:10 pm Post subject: Re: Gowesty gas tank vs others? |
MFerioli wrote: |
well, I noticed that the filler neck hole area was also dented so I ended up returning it and getting a new one. New one arrived today and only one corner is bent, no dents at all! I also ended up getting it 10$ cheaper. $172 and change all in.
Maybe I'll have the van back together soon and focus on other issues. ha! |
good on 'ya for doing the return...if we accept crap, we'll get crap, its only after the bean counters see that shipping is costing them only then will they make adjustments to packaging and/or lean on the shipper _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
MFerioli Samba Member
Joined: June 19, 2016 Posts: 127 Location: Colorado Springs
Posted: Fri Aug 01, 2025 11:32 am Post subject: Re: Gowesty gas tank vs others? |
Maybe I'll have the van back together soon and focus on other issues. ha! _________________ 1989 Westfalia full camper, 2WD, 4-speed, 2.1 WBX |
Posted: Thu Jul 17, 2025 10:21 am Post subject: Re: Gowesty gas tank vs others? |
thanks for the link, I was going to look for some sealant like that.
Excellent work on that tank mod, you shouldn't have any issue with that setup.
I agree, all these companies know how to make the tank, it's more of whether they choose to do a good job or just don't care much. For some reason though, none of them seem to care about packing them well for shipping. _________________ 1989 Westfalia full camper, 2WD, 4-speed, 2.1 WBX |
Ninz306 Samba Member
Posted: Thu Jul 17, 2025 9:38 am Post subject: Re: Gowesty gas tank vs others? |
I bought a Cip 1 tank. Seems fine to me. I dont think theres a significant amount of engineering that goes into a gas tank. The point of failure seems to be in the aftermarket fuel level sensors and the rubber gromets that will eventually fail. I opted to weld bungs on a new gas tank and fabricated a ring with nut rivets for the fuel sending units. The wet spots are from soapy water after I pushed compressed air into the tank to detect leaks. Proud to say it hasn't leaked.
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5707 Location: Bemidji, MN
Posted: Thu Jul 17, 2025 7:34 am Post subject: Re: Gowesty gas tank vs others? |
if you haven't installed the dented tank yet, i would apply Permatex Motoseal to the rubber grommets. in addition to sealing well and gasoline resistant, it also secures the grommets from accidentally being pushed in while wrassling the vent tubes.
https://www.permatex.com/products/gasketing/specia...ey-2-7-oz/ _________________ -dan
www.thefixitworkshop.com |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2631 Location: Southeast Kentucky
Posted: Wed Jul 16, 2025 7:31 pm Post subject: Re: Gowesty gas tank vs others? |
The seals will be just fine!
Install it and move on!  _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
Joined: January 01, 2007 Posts: 17850 Location: sticksville, ct.
Posted: Wed Jul 16, 2025 5:07 pm Post subject: Re: Gowesty gas tank vs others? |
fuck that
get a new tank. that won't ever work out well enough to use long term imho _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
zerotofifty Samba Member
Posted: Wed Jul 16, 2025 3:17 pm Post subject: Re: Gowesty gas tank vs others? |
MFerioli wrote: |
well, I put the new grommets in there and they seem to seal nice and tight. I think I'll just roll with it as is. I don't think working out the dent will really make any difference in the seal as it sits now. Hopefully I can be putting this in soon.
The tank paint looks good and the steel feels plenty thick. So far, I don't see any obvious issues with this manufacturer. $182.90 to my door from shitty walmart. Plus some cash back through capital one shopping and capital one CC miles. I don't feel great about it, but it was the best deal I could find on a brand tank that I'd seen at other sellers and mentioned here.
Thanks for the thoughts. |
I have found Walmart to be pretty fucking good. Great prices on many things. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Posted: Wed Jul 16, 2025 11:22 am Post subject: Re: Gowesty gas tank vs others? |
Thanks for the thoughts. _________________ 1989 Westfalia full camper, 2WD, 4-speed, 2.1 WBX |
Posted: Wed Jul 16, 2025 10:47 am Post subject: Re: Gowesty gas tank vs others? |
return wouldn't be an issue. dent roulette all over again though.
I don't have slide hammer experience, maybe I can rent one and give it a try? I was thinking a tool used for paintless dent repair, something curved to get up in there and massage it could work.
I wish I just got the bent tabs. Ha! _________________ 1989 Westfalia full camper, 2WD, 4-speed, 2.1 WBX |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23879 Location: NYC/Upstate/ROW
Posted: Wed Jul 16, 2025 9:48 am Post subject: Re: Gowesty gas tank vs others? |
Pop them out with a slide hammer and some hardware. 10x faster than a return which will come ship damaged again,anyway. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Wed Jul 16, 2025 8:58 am Post subject: Re: Gowesty gas tank vs others? |
if you got time for it to sort out - what's the replacement/return policy for your seller? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Wed Jul 16, 2025 8:20 am Post subject: Re: Gowesty gas tank vs others? |
Aside from the shipping dents, the tank looks good. Made in Taiwan.
Posted: Wed Jul 16, 2025 8:07 am Post subject: Re: Gowesty gas tank vs others? |
I got the tank. I'm concerned about the location of these dents. I'm afraid the grommets won't seal well. I haven't dry fit anything yet though. Of course, my dents had to be in that spot. ugh
Posted: Wed Jul 09, 2025 3:23 pm Post subject: Re: Gowesty gas tank vs others? |
I ended up going with a spectra tank. I based that on not being able to determine if I am really getting meaningfully better quality from a more expensive tank that I would have to pay to ship. Plus, I got 15% back through capitol one.
If I had unlimited resources, then maybe I would support a smaller business and buy from a VW specific vendor. Which I do for most other van parts.
I'll post about the visible quality when I get it. _________________ 1989 Westfalia full camper, 2WD, 4-speed, 2.1 WBX |
