Fuse panel wiring
hutmo
hutmo is offline
PostPosted: Fri Jun 27, 2025 8:24 am    Post subject: Re: Fuse panel wiring Reply with quote
Remove the fuse(s), then check the fuse terminals top and bottom for power using a multi meter. Whatever side has the power without the fuse is the feed side.
Best regards,
Chris
What if the Hokey Pokey really is what it is all about?
Samba Member #1115
Joined Feb 6, 2002
martyrg
martyrg is offline
PostPosted: Thu Jun 26, 2025 10:01 am    Post subject: Re: Fuse panel wiring Reply with quote
It's a 1978 Westfalia.
telford dorr
telford dorr is offline
PostPosted: Wed Jun 25, 2025 9:28 pm    Post subject: Re: Fuse panel wiring Reply with quote
It varies by year.
On earlier buses, the power went to the headlight switch, then to the ignition switch, then to the fuse block. In later years, it went directly to the fuse block.
General fuse block organization: First 6 fuses are taillights and headlights. Fuse 7 is generally a spare, but goes to the roadside parking lights in Europe. After that are fuses fed by the ignition switch. Finally are fuses fed directly by the battery.
The input sides of the fuses have busbars tying them together in groups. The output sides of the fuses are always individual connections.
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Jun 25, 2025 6:50 pm    Post subject: Re: Fuse panel wiring Reply with quote
what year bus are we dealing with?
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jun 25, 2025 4:38 pm    Post subject: Re: Fuse panel wiring Reply with quote
I think it is unique to how VW did things in that era. In general messy. Some fuses have their own supply wires, some have a buss connecting several. Some are in other places in the bus. Start by getting the wiring diagram for your year bus and the page in the owners' manual with the fuses on it. I download the wiring diagram to a flash drive and take it to a print shop like FEDEX etc who have plotters, then print a large version of it I can work with. Actually I print several so I can scribble on one as I check circuits, and keep a couple others unmolested. If you have a year bus that the wiring diagram is poor, use the next year also to make it easier to read. They are in Technical at the top of this page.
martyrg
martyrg is offline
PostPosted: Wed Jun 25, 2025 4:20 pm    Post subject: Fuse panel wiring Reply with quote
Does the factory wiring of the fuse panel follow any particular convention?
For example, does the power feed enter the top side of the fuse panel, then travel through the fuse, and then gets distributed throughout the bus?
